Salta al contenuto principale
Acer Aspire 4743-6481 Screen Replacement
Cosa ti serve
  1. Acer Aspire 4743-6481 Screen Replacement, Battery: passo 1, immagine 1 di 1
    • Turn over the laptop to view the underside.
  2. Acer Aspire 4743-6481 Screen Replacement: passo 2, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Use tweezers (or a similar tool) to slide the orange push pin. To release the battery, push it to the left.
  3. Acer Aspire 4743-6481 Screen Replacement: passo 3, immagine 1 di 1
    • You can lift the battery up and out now.
  4. Acer Aspire 4743-6481 Screen Replacement, Screen: passo 4, immagine 1 di 1
    • Position the laptop so you have a clear view of the front of the screen.
    • Remove the two screw covers at the bottom sides of the screen casing using a flat tool.
    • Remove the two 5.0 mm Phillips screws. They will be directly underneath the screw covers.
  5. Acer Aspire 4743-6481 Screen Replacement: passo 5, immagine 1 di 1
    • Use a flat tool, to pry open along every side of the front casing of the screen.
    • It will require a small amount of force to grudge open. Make sure every side of the casing is loose before removing it.
    • You should use a metal pry tool only if you are unsuccessful with a plastic one. The metal tool could cause damage to your device.
  6. Acer Aspire 4743-6481 Screen Replacement: passo 6, immagine 1 di 1
    • Remove the front casing.
    • Remove the four 5.0 mm Phillips screws located next to every corner of the screen.
  7. Acer Aspire 4743-6481 Screen Replacement: passo 7, immagine 1 di 1
    • After removing the screws, gently place the screen on top of the keyboard.
    • Do not attempt to remove the screen yet since it is not fully disconnected from the laptop.
    • You may use a piece of cloth or similar material beneath the new screen to avoid scratching it with the other surface.
  8. Acer Aspire 4743-6481 Screen Replacement: passo 8, immagine 1 di 3 Acer Aspire 4743-6481 Screen Replacement: passo 8, immagine 2 di 3 Acer Aspire 4743-6481 Screen Replacement: passo 8, immagine 3 di 3
    • Gently remove the tape that covers the connector cable, as highlighted in the first picture.
    • With a flat tool, gently disconnect the connector cable from the damaged screen.
  9. Acer Aspire 4743-6481 Screen Replacement: passo 9, immagine 1 di 1
    • Remove the four remaining 3.5 mm Phillips screws from the screen piece.
    • There will be two screws on each side, one on the bottom and another on the top.
  10. Acer Aspire 4743-6481 Screen Replacement: passo 10, immagine 1 di 1
    • The screen can be easily removed from its frame now.
Conclusione
To reassemble your device, carefully follow these instructions in reverse order.
Altre 3 persone hanno completato questa guida.
Juan Seijas
Membro da: 02/15/17
238 Reputazione
1 Guida realizzata
USF Tampa, Team S5-G1, Lacy Spring 2017 Membro di USF Tampa, Team S5-G1, Lacy Spring 2017
USFT-LACY-S17S5G1
4 Membri
5 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 41
Tutti i Tempi: 1,953
