Salta al contenuto principale
Acer Aspire 4743-6481 Ram Card Replacement
Cosa ti serve
  1. Acer Aspire 4743-6481 Ram Card Replacement, Battery: passo 1, immagine 1 di 1
    • Turn over the laptop to view the underside.
  2. Acer Aspire 4743-6481 Ram Card Replacement: passo 2, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Use tweezers (or a similar tool) to slide the orange push pin. To release the battery, push it to the left.
  3. Acer Aspire 4743-6481 Ram Card Replacement: passo 3, immagine 1 di 1
    • You can lift the battery up and out now.
  4. Acer Aspire 4743-6481 Ram Card Replacement, RAM Card: passo 4, immagine 1 di 1
    • Remove three 7.0 mm screws with a Phillips head screwdriver from the back panel to gain access to the RAM cards.
  5. Acer Aspire 4743-6481 Ram Card Replacement: passo 5, immagine 1 di 1
    • Place the device with the battery side facing up, as shown on the picture.
    • After removing the back panel, you will see the RAM cards located to the right.
  6. Acer Aspire 4743-6481 Ram Card Replacement: passo 6, immagine 1 di 1
    • You should notice a silver tab on each side of the RAM card. Push each tab away at the same time to detach the card.
  7. Acer Aspire 4743-6481 Ram Card Replacement: passo 7, immagine 1 di 1
    • If done successfully, the RAM should pop out and you can lift it out with no effort.
Conclusione
AL-Moatasem
Membro da: 02/22/17
101 Reputazione
1 Guida realizzata
USF Tampa, Team S5-G1, Lacy Spring 2017 Membro di USF Tampa, Team S5-G1, Lacy Spring 2017
USFT-LACY-S17S5G1
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 34
Tutti i Tempi: 890
