Salta al contenuto principale
Acer Aspire 4743-6481 Keyboard Replacement
Cosa ti serve
  1. Acer Aspire 4743-6481 Keyboard Replacement, Battery: passo 1, immagine 1 di 1
    • Turn over the laptop to view the underside.
  2. Acer Aspire 4743-6481 Keyboard Replacement: passo 2, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Use tweezers (or a similar tool) to slide the orange push pin. To release the battery, push it to the left.
  3. Acer Aspire 4743-6481 Keyboard Replacement: passo 3, immagine 1 di 1
    • You can lift the battery up and out now.
  4. Acer Aspire 4743-6481 Keyboard Replacement, Keyboard: passo 4, immagine 1 di 1
    • Remove the two 6.0 mm screws that secure the keyboard using a Phillips head screwdriver.
    • They can be easily identified by looking for the screws with the keyboard icon next to them.
  5. Acer Aspire 4743-6481 Keyboard Replacement: passo 5, immagine 1 di 2 Acer Aspire 4743-6481 Keyboard Replacement: passo 5, immagine 2 di 2
    • Turn the laptop over and open it.
    • Use flat edged tools to gently separate the keyboard from the laptop. It should snap off with a small amount of force.
    • Be sure to push the small tabs along the top of the keyboard, while lifting to successfully free the keyboard.
  6. Acer Aspire 4743-6481 Keyboard Replacement: passo 6, immagine 1 di 1
    • Gently lift away the keyboard, making sure not to damage the data cable or the connector.
    • The connection is located beneath the bottom center of the keyboard.
  7. Acer Aspire 4743-6481 Keyboard Replacement: passo 7, immagine 1 di 1
    • Remove piece of tape that covers the connection between the data cable and the connector.
  8. Acer Aspire 4743-6481 Keyboard Replacement: passo 8, immagine 1 di 1
    • Detach the data cable by flipping up the small black latch on the connector.
    • Once the latch is lifted, the keyboard should be completely free.
Conclusione
Altre 3 persone hanno completato questa guida.
David Veres
Membro da: 02/22/17
140 Reputazione
1 Guida realizzata
USF Tampa, Team S5-G1, Lacy Spring 2017 Membro di USF Tampa, Team S5-G1, Lacy Spring 2017
USFT-LACY-S17S5G1
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 31
Tutti i Tempi: 1,568
