Introduzione
If your Acer Aspire 4741G-332G32Mn is not functioning properly, use this guide to remove the backplate to ensure the device is functioning successfully.
The backplate is found on the back of the device and provides sturdy stability. The backplate ensures that the central processing unit (CPU) is securely protected.
Before using this guide, inspect the backplate and ensure it is connected to the underside of the device. Make sure the backplate is screwed securely into the device before removing it.
Before beginning, make sure to power off your device completely and disconnect from any external power source.
Cosa ti serve
Pry off the keyboard using the opening tool.
Remove the two screws that are connected to the motherboard using a Phillips #0 screwdriver.
