Salta al contenuto principale
Acer Aspire 4520-5464 WiFi Wireless Card Replacement
Cosa ti serve
  1. Acer Aspire 4520-5464 WiFi Wireless Card Replacement, Battery: passo 1, immagine 1 di 1
    • Shut down the computer and disconnect all external devices and cables.
    • Flip the computer over.
  2. Acer Aspire 4520-5464 WiFi Wireless Card Replacement: passo 2, immagine 1 di 2 Acer Aspire 4520-5464 WiFi Wireless Card Replacement: passo 2, immagine 2 di 2
    • Ensure that the battery compartment lock tab is in the unlocked position.
    • Slide the sliding black tab away from the battery compartment.
    • The inside edge of the battery should be released, causing it to slightly pop out of the compartment.
  3. Acer Aspire 4520-5464 WiFi Wireless Card Replacement: passo 3, immagine 1 di 1
    • Grasp the inside edge of the battery and lift to fully detach the battery from the computer.
  4. Acer Aspire 4520-5464 WiFi Wireless Card Replacement, WiFi Wireless Card: passo 4, immagine 1 di 2 Acer Aspire 4520-5464 WiFi Wireless Card Replacement, WiFi Wireless Card: passo 4, immagine 2 di 2
    • Using the Phillips #1 screwdriver, remove the two 0.5mm screws from the smallest panel on the back of the computer.
    • Set the screws aside.
    • Lift up the panel using the indent located on the left side of the panel.
  5. Acer Aspire 4520-5464 WiFi Wireless Card Replacement: passo 5, immagine 1 di 1
    • Remove both the black and white wires by pinching the brass connectors and pulling up.
  6. Acer Aspire 4520-5464 WiFi Wireless Card Replacement: passo 6, immagine 1 di 1
    • Remove the two 0.5mm Phillips #1 black screws located on the WiFi card.
  7. Acer Aspire 4520-5464 WiFi Wireless Card Replacement: passo 7, immagine 1 di 1
    • Lift the WiFi card on the left side to remove it.
Conclusione
To reassemble your device, follow these instructions in reverse order with a new WiFi wireless card.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 13
Tutti i Tempi: 1,028
