Salta al contenuto principale
Acer Aspire 4520-5464 RAM Replacement
Cosa ti serve
  1. Acer Aspire 4520-5464 RAM Replacement, Battery: passo 1, immagine 1 di 1
    • Shut down the computer and disconnect all external devices and cables.
    • Flip the computer over.
  2. Acer Aspire 4520-5464 RAM Replacement: passo 2, immagine 1 di 2 Acer Aspire 4520-5464 RAM Replacement: passo 2, immagine 2 di 2
    • Ensure that the battery compartment lock tab is in the unlocked position.
    • Slide the sliding black tab away from the battery compartment.
    • The inside edge of the battery should be released, causing it to slightly pop out of the compartment.
  3. Acer Aspire 4520-5464 RAM Replacement: passo 3, immagine 1 di 1
    • Grasp the inside edge of the battery and lift to fully detach the battery from the computer.
  4. Acer Aspire 4520-5464 RAM Replacement, RAM: passo 4, immagine 1 di 2 Acer Aspire 4520-5464 RAM Replacement, RAM: passo 4, immagine 2 di 2
    • Remove the seven 2mm Phillips #1 screws from the largest panel on back of the laptop.
    • Lift up the panel from the indent located on the right side.
  5. Acer Aspire 4520-5464 RAM Replacement: passo 5, immagine 1 di 3 Acer Aspire 4520-5464 RAM Replacement: passo 5, immagine 2 di 3 Acer Aspire 4520-5464 RAM Replacement: passo 5, immagine 3 di 3
    • Push the white tabs located on either side of the top stick of RAM outward.
    • Remove the RAM from the slot on the motherboard.
    • Repeat for the bottom stick of RAM.
Conclusione
Un commento
interesting good job
Maren Eras - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 24
Tutti i Tempi: 1,368
