Salta al contenuto principale
Acer Aspire 4520-5464 Keyboard Replacement
Cosa ti serve
  1. Acer Aspire 4520-5464 Keyboard Replacement, Battery: passo 1, immagine 1 di 1
    • Shut down the computer and disconnect all external devices and cables.
    • Flip the computer over.
  2. Acer Aspire 4520-5464 Keyboard Replacement: passo 2, immagine 1 di 2 Acer Aspire 4520-5464 Keyboard Replacement: passo 2, immagine 2 di 2
    • Ensure that the battery compartment lock tab is in the unlocked position.
    • Slide the sliding black tab away from the battery compartment.
    • The inside edge of the battery should be released, causing it to slightly pop out of the compartment.
  3. Acer Aspire 4520-5464 Keyboard Replacement: passo 3, immagine 1 di 1
    • Grasp the inside edge of the battery and lift to fully detach the battery from the computer.
  4. Acer Aspire 4520-5464 Keyboard Replacement, Keyboard: passo 4, immagine 1 di 1
    • Remove the five 1mm Phillips #1 screws located inside of the battery compartment.
    • Remove the three 2mm Phillips #1 screws located at the top of the case's perimeter.
  5. Acer Aspire 4520-5464 Keyboard Replacement: passo 5, immagine 1 di 2 Acer Aspire 4520-5464 Keyboard Replacement: passo 5, immagine 2 di 2
    • Remove the gray plastic section located above the keyboard using the prying tool.
    • Lift off of the keyboard.
  6. Acer Aspire 4520-5464 Keyboard Replacement: passo 6, immagine 1 di 2 Acer Aspire 4520-5464 Keyboard Replacement: passo 6, immagine 2 di 2
    • Take hold of the keyboard behind the function keys and lift gently.
    • Do not completely separate the keyboard from the laptop.
  7. Acer Aspire 4520-5464 Keyboard Replacement: passo 7, immagine 1 di 2 Acer Aspire 4520-5464 Keyboard Replacement: passo 7, immagine 2 di 2
    • Lift up the black locking tab located where the keyboard is attached to the laptop.
    • Pull the keyboard cable towards the trackpad and remove the keyboard.
Conclusione
To reassemble your device, follow these instructions in reverse order using your new keyboard.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 592
