Salta al contenuto principale
Acer Aspire 4520-5464 Battery Replacement
  1. Acer Aspire 4520-5464 Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Shut down the computer and disconnect all external devices and cables.
    • Flip the computer over.
  2. Acer Aspire 4520-5464 Battery Replacement: passo 2, immagine 1 di 2 Acer Aspire 4520-5464 Battery Replacement: passo 2, immagine 2 di 2
    • Ensure that the battery compartment lock tab is in the unlocked position.
    • Slide the sliding black tab away from the battery compartment.
    • The inside edge of the battery should be released, causing it to slightly pop out of the compartment.
  3. Acer Aspire 4520-5464 Battery Replacement: passo 3, immagine 1 di 1
    • Grasp the inside edge of the battery and lift to fully detach the battery from the computer.
Conclusione
To reassemble your device, follow these instructions in reverse order using a new battery.
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 427
