Introduzione
In this guide, you will be instructed on how to replace the optical drive in your laptop. Your optical drive allows for your computer to read CD ROMs.
This replacement is a bit difficult, and will take you 9 steps to complete. However, you must remove the hard drive, internal fan, and battery first.
Cosa ti serve
Turn the Acer Aspire 3003WLCi so that the bottom of the laptop is facing up. Orient it so that the battery is on your left.
The panel you will be removing to access the internal fan is located at the bottom of the laptop.
Locate the hard drive access panel in the upper right corner of the laptop.
Turn the Acer Aspire 3003WLCi so that the back of the laptop is facing towards you.
You will be opening the tabs on the back of the laptop in order to access the internal components.
