Salta al contenuto principale
Acer Aspire 3 A315-24P-R7VH Wi-Fi Card Replacement
Cosa ti serve
  1. Acer Aspire 3 A315-24P-R7VH Wi-Fi Card Replacement, Wi-Fi Card: passo 1, immagine 1 di 1
    • Power off the laptop and unplug it from the wall charger.
  2. Acer Aspire 3 A315-24P-R7VH Wi-Fi Card Replacement: passo 2, immagine 1 di 1
    • Close the laptop and flip it over.
    • Using Phillips #1 Screwdriver, remove the eleven 6.5 mm Phillips screws from the lower case.
  3. Acer Aspire 3 A315-24P-R7VH Wi-Fi Card Replacement: passo 3, immagine 1 di 1
    • Insert an opening pick between the lower case and chassis.
    • Pry around the entire perimeter until the lower case releases.
    • Remove the lower case.
  4. Acer Aspire 3 A315-24P-R7VH Wi-Fi Card Replacement: passo 4, immagine 1 di 1
    • Disconnect the two antenna cables (black and white) from the Wi-Fi card.
    • Using Phillips #1 Screwdriver unscrew the 4.5 mm Phillips head screws that secure the Wi-Fi card.
  5. Acer Aspire 3 A315-24P-R7VH Wi-Fi Card Replacement: passo 5, immagine 1 di 1
    • Slide up the Wi-Fi module.
  6. Acer Aspire 3 A315-24P-R7VH Wi-Fi Card Replacement: passo 6, immagine 1 di 1
    • Carefully remove the Wi-Fi card from the module.
Conclusione
Gateway, Team 9-69, Gonzalez Spring 2024 Membro di Gateway, Team 9-69, Gonzalez Spring 2024
GCC-GONZALEZ-S24S9G69
5 Membri
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 15
Tutti i Tempi: 105
