Salta al contenuto principale
Acer Aspire 3 A315-24P-R7VH Display Assembly Replacement
Cosa ti serve
  1. Acer Aspire 3 A315-24P-R7VH Display Assembly Replacement, Lower Case: passo 1, immagine 1 di 1
    • Power off the machine and unplug it from the wall charger.
  2. Acer Aspire 3 A315-24P-R7VH Display Assembly Replacement: passo 2, immagine 1 di 2 Acer Aspire 3 A315-24P-R7VH Display Assembly Replacement: passo 2, immagine 2 di 2
    • Close the laptop and flip it over.
    • Remove the eleven 6.5 mm Phillips screws from the lower case.
  3. Acer Aspire 3 A315-24P-R7VH Display Assembly Replacement: passo 3, immagine 1 di 1
    • Insert an opening pick between the lower case and chassis.
    • Pry around the entire perimeter until the lower case releases.
    • Remove the lower case.
  4. Acer Aspire 3 A315-24P-R7VH Display Assembly Replacement: passo 4, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Anti-Static Wrist Strap
    $7.95
    Compra
    • Optional: Put on an anti-static wrist strap. Ground yourself by connecting the metal clip at the end to any unpainted metal surface outside of the laptop.
  5. Acer Aspire 3 A315-24P-R7VH Display Assembly Replacement, Display Assembly: passo 5, immagine 1 di 3 Acer Aspire 3 A315-24P-R7VH Display Assembly Replacement, Display Assembly: passo 5, immagine 2 di 3 Acer Aspire 3 A315-24P-R7VH Display Assembly Replacement, Display Assembly: passo 5, immagine 3 di 3
    • Disconnect the black and white antenna cables plugged into the network card on the motherboard.
    • Unscrew the four 5.5 mm Phillips screws holding the hinges of the monitor to the laptop frame.
  6. Acer Aspire 3 A315-24P-R7VH Display Assembly Replacement: passo 7, immagine 1 di 1
    • Once the hinges are unscrewed the display assembly will easily come off.
Conclusione
To reassemble you will just follow these steps in reverse order.
AlexHarpring
Membro da: 09/07/23
301 Reputazione
3 Guide realizzate
Gateway, Team 1-1, Pee Fall 2023 Membro di Gateway, Team 1-1, Pee Fall 2023
GCC-PEE-F23S1G1
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 46
Tutti i Tempi: 226
