Salta al contenuto principale
Acer Aspire 3 A315-21-92FX Hard Drive Replacement
Cosa ti serve
  1. Acer Aspire 3 A315-21-92FX Hard Drive Replacement, Hard Drive: passo 1, immagine 1 di 1
    • Please make sure that there is no external access to the battery, and the battery is out of power.
    • Flip the Acer Aspire 3 A315-21-92FX over, so the back-side is oriented to the upward position.
  2. Acer Aspire 3 A315-21-92FX Hard Drive Replacement: passo 2, immagine 1 di 2 Acer Aspire 3 A315-21-92FX Hard Drive Replacement: passo 2, immagine 2 di 2
    • Remove the single 2.5mm Phillips #0 screw.
  3. Acer Aspire 3 A315-21-92FX Hard Drive Replacement: passo 3, immagine 1 di 1
    • Use the iFixit opening tool to remove the cover of the hard disk.
  4. Acer Aspire 3 A315-21-92FX Hard Drive Replacement: passo 4, immagine 1 di 2 Acer Aspire 3 A315-21-92FX Hard Drive Replacement: passo 4, immagine 2 di 2
    • Pull the hard disk out of the Acer Aspire 3 A315-21-92FX slightly and slowly.
    • This laptop is missing the hard drive.
Conclusione
Altre 4 persone hanno completato questa guida.
2 Commenti
My acer aspire 3 A315-32 says no bootable device I had tried to boot Linux from USB but I partioned the hard drive so I fixed it by changing the format and deleting everything and installed windows on a different pc but it’s still not booting even on boot options it’s not showing
Zeek tuyishime - Replica
These connecting cable is missing, where to buy these cable. Pls tell the cable name
jayesh v v - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 17
Ultimi 30 Giorni: 66
Tutti i Tempi: 6,825
