Salta al contenuto principale
Acer Aspire 3 A315-21-92FX Battery Replacement
Cosa ti serve
  1. Acer Aspire 3 A315-21-92FX Battery Replacement, RAM: passo 1, immagine 1 di 1
    • Flip the Acer Aspire 3 A315-21-92FX over so the back-side is oriented to the upward position.
  2. Acer Aspire 3 A315-21-92FX Battery Replacement: passo 2, immagine 1 di 2 Acer Aspire 3 A315-21-92FX Battery Replacement: passo 2, immagine 2 di 2
    • Remove the single 2.5mm Phillips #0 screw.
  3. Acer Aspire 3 A315-21-92FX Battery Replacement: passo 3, immagine 1 di 1
    • Use the iFixit opening tool to remove the small cover.
  4. Acer Aspire 3 A315-21-92FX Battery Replacement: passo 4, immagine 1 di 3 Acer Aspire 3 A315-21-92FX Battery Replacement: passo 4, immagine 2 di 3 Acer Aspire 3 A315-21-92FX Battery Replacement: passo 4, immagine 3 di 3
    • Press the tabs on each side of the RAM outwards, and the memory module will pop up at an angle.
  5. Acer Aspire 3 A315-21-92FX Battery Replacement: passo 5, immagine 1 di 2 Acer Aspire 3 A315-21-92FX Battery Replacement: passo 5, immagine 2 di 2
    • Pull the RAM slowly out of the Acer Aspire 3 A315-21-92FX.
  6. Acer Aspire 3 A315-21-92FX Battery Replacement, Hard Drive: passo 6, immagine 1 di 1
    • Please make sure that there is no external access to the battery, and the battery is out of power.
    • Flip the Acer Aspire 3 A315-21-92FX over, so the back-side is oriented to the upward position.
  7. Acer Aspire 3 A315-21-92FX Battery Replacement: passo 7, immagine 1 di 2 Acer Aspire 3 A315-21-92FX Battery Replacement: passo 7, immagine 2 di 2
  8. Acer Aspire 3 A315-21-92FX Battery Replacement: passo 8, immagine 1 di 1
    • Use the iFixit opening tool to remove the cover of the hard disk.
  9. Acer Aspire 3 A315-21-92FX Battery Replacement: passo 9, immagine 1 di 2 Acer Aspire 3 A315-21-92FX Battery Replacement: passo 9, immagine 2 di 2
    • Pull the hard disk out of the Acer Aspire 3 A315-21-92FX slightly and slowly.
    • This laptop is missing the hard drive.
  10. Acer Aspire 3 A315-21-92FX Battery Replacement, Battery: passo 10, immagine 1 di 1
    • Remove fourteen 2.5mm Phillips #0 screws from the back of the laptop.
    • There may be two additional screws under the hard drive cover that must be removed before attempting to remove the back cover.
  11. Acer Aspire 3 A315-21-92FX Battery Replacement: passo 11, immagine 1 di 3 Acer Aspire 3 A315-21-92FX Battery Replacement: passo 11, immagine 2 di 3 Acer Aspire 3 A315-21-92FX Battery Replacement: passo 11, immagine 3 di 3
    • Use the iFixit opening tool to remove the back cover.
  12. Acer Aspire 3 A315-21-92FX Battery Replacement: passo 12, immagine 1 di 2 Acer Aspire 3 A315-21-92FX Battery Replacement: passo 12, immagine 2 di 2
    • Pull out the plug connecting the battery to the motherboard.
  13. Acer Aspire 3 A315-21-92FX Battery Replacement: passo 13, immagine 1 di 2 Acer Aspire 3 A315-21-92FX Battery Replacement: passo 13, immagine 2 di 2
    • Pull the battery out of the groove.
Conclusione
Altre 6 persone hanno completato questa guida.
Un commento
Thanks for this tutorial ! You just forgot 3 screws: 2 on the right of the hard drive, and 1 on the top left =)
Troublicious - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 9
Ultimi 7 Giorni: 48
Ultimi 30 Giorni: 262
Tutti i Tempi: 11,714
