Salta al contenuto principale
Acer AL1714 Power Button Circuit Board
Cosa ti serve
  1. Acer AL1714 Power Button Circuit Board, Power Button Circuit Board: passo 1, immagine 1 di 2 Acer AL1714 Power Button Circuit Board, Power Button Circuit Board: passo 1, immagine 2 di 2
    • Turn the monitor facedown.
    • Unscrew the 5 screws holding the back cover on.
    • (This may require flipping the monitor over and shaking the screws loose once they're already unscrewed)
  2. Acer AL1714 Power Button Circuit Board: passo 2, immagine 1 di 3 Acer AL1714 Power Button Circuit Board: passo 2, immagine 2 di 3 Acer AL1714 Power Button Circuit Board: passo 2, immagine 3 di 3
    • Take the edge tool or a metal ruler and insert it into the bezel.
    • Apply pressure and push down.
    • Do the same to the right side.
    • Once the side of bezel facing you is decoupled, take the back cover and pry it loose.
  3. Acer AL1714 Power Button Circuit Board: passo 3, immagine 1 di 3 Acer AL1714 Power Button Circuit Board: passo 3, immagine 2 di 3 Acer AL1714 Power Button Circuit Board: passo 3, immagine 3 di 3
    • Remove the Flat Flex Cable from the Power Supply Board under the metal cover.
    • Pull the cord back and out of the way.
    • (It may be stuck down with adhesive)
  4. Acer AL1714 Power Button Circuit Board: passo 4, immagine 1 di 3 Acer AL1714 Power Button Circuit Board: passo 4, immagine 2 di 3 Acer AL1714 Power Button Circuit Board: passo 4, immagine 3 di 3
    • Unscrew the cord anchors for the VGA port.
    • (Use needle nose pliers if they're too tight for removal by hand)
  5. Acer AL1714 Power Button Circuit Board: passo 5, immagine 1 di 2 Acer AL1714 Power Button Circuit Board: passo 5, immagine 2 di 2
    • Turn the monitor around.
    • Unscrew the 1 screw holding the Flex Power Cable cover.
    • Lift up and remove the Flex Power Cable cover.
    • (Careful: This may be sharp)
  6. Acer AL1714 Power Button Circuit Board: passo 6, immagine 1 di 1
    • Unscrew the 5 screws holding the metal cage on.
  7. Acer AL1714 Power Button Circuit Board: passo 7, immagine 1 di 2 Acer AL1714 Power Button Circuit Board: passo 7, immagine 2 di 2
    • Lift up on the back of the metal cage slightly.
    • Pull the cage toward self.
    • (Must be careful to free the cover of the VGA port and power supply input)
  8. Acer AL1714 Power Button Circuit Board: passo 8, immagine 1 di 3 Acer AL1714 Power Button Circuit Board: passo 8, immagine 2 di 3 Acer AL1714 Power Button Circuit Board: passo 8, immagine 3 di 3
    • Lift up on the Flat Flex Cable holder tabs to release cords.
    • Lift up on the Flat Flex Cables and bend them out of the working area.
  9. Acer AL1714 Power Button Circuit Board: passo 9, immagine 1 di 3 Acer AL1714 Power Button Circuit Board: passo 9, immagine 2 di 3 Acer AL1714 Power Button Circuit Board: passo 9, immagine 3 di 3
    • Unplug the 4 backlight wires from their ports on the Power Supply Board.
    • (Considering their size, the best way to unplug the backlight wires is by slowly jiggling wires out of place)
  10. Acer AL1714 Power Button Circuit Board: passo 10, immagine 1 di 1
    • Unscrew the 5 screws holding the Power Supply Board and Video Display boards on.
  11. Acer AL1714 Power Button Circuit Board: passo 11, immagine 1 di 2 Acer AL1714 Power Button Circuit Board: passo 11, immagine 2 di 2
    • Lift up and remove the joined Power Supply Board and Video Display boards.
  12. Acer AL1714 Power Button Circuit Board: passo 12, immagine 1 di 3 Acer AL1714 Power Button Circuit Board: passo 12, immagine 2 di 3 Acer AL1714 Power Button Circuit Board: passo 12, immagine 3 di 3
    • Carefully detach the Power Supply and Video Display boards at their connector joint.
    • (This step is not necessary for the removal and replacement of the Power Button Circuit board)
    • (This is only a precaution so as not to bend or break the connector joint between the two boards)
  13. Acer AL1714 Power Button Circuit Board: passo 13, immagine 1 di 1
    • Remove the Flat Flex Cable from the Power Button Circuit Board.
  14. Acer AL1714 Power Button Circuit Board: passo 14, immagine 1 di 3 Acer AL1714 Power Button Circuit Board: passo 14, immagine 2 di 3 Acer AL1714 Power Button Circuit Board: passo 14, immagine 3 di 3
    • Grasp, lift, and remove the LCD Module from the front panel.
  15. Acer AL1714 Power Button Circuit Board: passo 15, immagine 1 di 2 Acer AL1714 Power Button Circuit Board: passo 15, immagine 2 di 2
    • Unscrew the 2 screws holding the Power Button Circuit Board.
  16. Acer AL1714 Power Button Circuit Board: passo 16, immagine 1 di 1
    • Lift and remove the Power Button Circuit Board.
Conclusione
Altre 3 persone hanno completato questa guida.
USF Tampa, Team 1-3, Brown Fall 2014 Membro di USF Tampa, Team 1-3, Brown Fall 2014
USFT-BROWN-F14S1G3
3 Membri
5 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 16
Tutti i Tempi: 1,755
