Salta al contenuto principale
Acer AL1714 Power Button Circuit Board Flat Flex Cables Replacement
Cosa ti serve
  1. Acer AL1714 Power Button Circuit Board  Flat Flex Cables Replacement, Power Button Circuit Board Flat Flex Cables: passo 1, immagine 1 di 2 Acer AL1714 Power Button Circuit Board  Flat Flex Cables Replacement, Power Button Circuit Board Flat Flex Cables: passo 1, immagine 2 di 2
    • Turn the monitor facedown.
    • Unscrew the 5 screws holding the back cover on.
    • (This may require flipping the monitor and shaking the screws loose once they're already unscrewed)
  2. Acer AL1714 Power Button Circuit Board  Flat Flex Cables Replacement: passo 2, immagine 1 di 3 Acer AL1714 Power Button Circuit Board  Flat Flex Cables Replacement: passo 2, immagine 2 di 3 Acer AL1714 Power Button Circuit Board  Flat Flex Cables Replacement: passo 2, immagine 3 di 3
    • Take the edge tool or a metal ruler and insert it into the bezel.
    • Apply pressure and push down.
    • Do the same to the right side.
    • Once side of bezel facing you is decoupled, take the back cover and pry it loose.
  3. Acer AL1714 Power Button Circuit Board  Flat Flex Cables Replacement: passo 3, immagine 1 di 3 Acer AL1714 Power Button Circuit Board  Flat Flex Cables Replacement: passo 3, immagine 2 di 3 Acer AL1714 Power Button Circuit Board  Flat Flex Cables Replacement: passo 3, immagine 3 di 3
    • Remove the Power Button Circuit board Flat Flex Cable from the Power Supply board under the metal cage.
    • Pull the cord back and out of the way.
    • (It may be stuck down with adhesive)
  4. Acer AL1714 Power Button Circuit Board  Flat Flex Cables Replacement: passo 4, immagine 1 di 1
    • Remove the Flat Flex Cables from the Power Button Circuit Board.
Conclusione
USF Tampa, Team 1-3, Brown Fall 2014 Membro di USF Tampa, Team 1-3, Brown Fall 2014
USFT-BROWN-F14S1G3
3 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 7
Tutti i Tempi: 663
