Salta al contenuto principale
Access to the main components of the why! N240JU
Cosa ti serve
  1. Access to the main components of the why! N240JU, Battery: passo 1, immagine 1 di 2 Access to the main components of the why! N240JU, Battery: passo 1, immagine 2 di 2
    • Start by unlocking the right locking latch.
    • Then, by simultaneously unlocking the left latch, lift the battery out of its socket.
  2. Access to the main components of the why! N240JU, Access to main components: passo 2, immagine 1 di 2 Access to the main components of the why! N240JU, Access to main components: passo 2, immagine 2 di 2
    • Begin by spotting the dummy memory card.
    • Then, remove it and put it on your workplan.
  3. Access to the main components of the why! N240JU: passo 3, immagine 1 di 3 Access to the main components of the why! N240JU: passo 3, immagine 2 di 3 Access to the main components of the why! N240JU: passo 3, immagine 3 di 3
    • Locate the 15 screws that hold the bottom cover of the device in place.
    • Unscrew them and place them on your work surface.
    • Then, un-clip the bottom cover, starting with the side shown in the third picture.
Conclusione
Un ringraziamento speciale a questi traduttori:
fr en
100%
Questi traduttori ci stanno aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
Felice Suglia
Membro da: 06/15/13
33.538 Reputazione
283 Guide realizzate
4Commenti sulla guida
J’ai effectivement pu démonter et remonter la base de l’ordinateur pour accéder au ventilateur, ceci en 15 minutes. Pour aller aussi vite, j’ai utilisé une visseuse - dé-visseuse.
J’ai eu des problèmes de surchauffe de l’ordinateur, il semble que le ventilateur ne refroidisse pas assez dans certaines circonstance, en particulier lors de réunion “google meet” avec plus d’une dizaine de participants et des partages d’écran. Ce problème, je n’ai pas réussi à le résoudre.
Mais l’ouverture et la fermeture de l’ordinateur est effectivement très simple, merci.
Bernard Gisin - Replica
Pour plus d’informations à ce sujet, voir https://swisslinux.org/forum/viewtopic.p....
Cordialement.
Felice Suglia - Replica
J’ai réussi à rapidement changer la batterie Cmos, mais l’ordinateur ne redémarre quand même pas et m’invite à définir un boot device. Qu’est-ce que je dois faire?
Michael Fleckenstein - Replica
Bonjour,
Si l'ordinateur vous demande de définir un boot device, il redémarre, mais dans le BIOS. Il semblerait que c'est votre session qui ne redémarre pas et si la session n'est pas vue, vous pourriez voir depuis votre BIOS si le mode UEFI est activé ou non. Le statut du mode UEFI est modifié lorsqu'en change la pile CMOS.
Cordiales salutations.
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 8
Tutti i Tempi: 748
