Salta al contenuto principale
Aarp RealPad MA7BX2 Speakers Replacement
Cosa ti serve
  1. Aarp RealPad MA7BX2 Speakers Replacement, Speakers: passo 1, immagine 1 di 1
    • Loosen the back cover using the suction cup.
    • Pull up on all four corners of the back with the suction cup.
  2. Aarp RealPad MA7BX2 Speakers Replacement: passo 2, immagine 1 di 1
    • Gently place the small opening tool in the crevice created by loosening the back.
    • Slide the opening tool around the edges of the device.
    • Wedge it open using the plastic opening tool.
  3. Aarp RealPad MA7BX2 Speakers Replacement: passo 3, immagine 1 di 1
    • Gently pull off the black tape.
  4. Aarp RealPad MA7BX2 Speakers Replacement: passo 4, immagine 1 di 1
    • Remove the wires with the tweezers by pulling them upward.
  5. Aarp RealPad MA7BX2 Speakers Replacement: passo 5, immagine 1 di 2 Aarp RealPad MA7BX2 Speakers Replacement: passo 5, immagine 2 di 2
    • Pull the speakers upward with you hand.
Conclusione
To reassemble your device you will need to solder the wires back in position and then follow the other steps in reverse order.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 180
