Salta al contenuto principale
AYL SoundFit Speaker Replacement
Cosa ti serve
  1. AYL SoundFit Speaker Replacement, Motherboard: passo 1, immagine 1 di 1
    • Unscrew the four hex screws on the top of the device using a 2.5mm hex screwdriver.
  2. AYL SoundFit Speaker Replacement: passo 2, immagine 1 di 1
    • Place a spudger between the black plastic cover and the green case.
    • Remove the black cover away from the main casing and remove the cover.
  3. AYL SoundFit Speaker Replacement: passo 3, immagine 1 di 1
    • Place the spudger tool between the black housing, which contains the woofer, and the outer rubber casing.
    • Remove the housing away from the body to reveal the motherboard, speaker, and battery.
  4. AYL SoundFit Speaker Replacement: passo 4, immagine 1 di 2 AYL SoundFit Speaker Replacement: passo 4, immagine 2 di 2
    • Remove the two Phillips screws which hold its battery casing on the housing using a PH00 Phillips screwdriver.
    • Remove the battery case to reveal the battery.
  5. AYL SoundFit Speaker Replacement: passo 5, immagine 1 di 1
    • Using a soldering iron, heat up and remove both the positive and negative battery contacts from the motherboard.
  6. AYL SoundFit Speaker Replacement: passo 6, immagine 1 di 3 AYL SoundFit Speaker Replacement: passo 6, immagine 2 di 3 AYL SoundFit Speaker Replacement: passo 6, immagine 3 di 3
    • Remove all three Phillips screws which holds the motherboard to the base using a PH00 Phillips screwdriver.
    • The motherboard can now be wiggled free from the base.
  7. AYL SoundFit Speaker Replacement, Speaker: passo 7, immagine 1 di 1
    • Using a soldering iron, heat up and remove the positive and negative wire contacts from the motherboard.
  8. AYL SoundFit Speaker Replacement: passo 8, immagine 1 di 1
    • Remove four Phillips #1 screws to detach the speaker form the module.
    • Extract the speaker from the body of the AYL SoundFit.
Conclusione
Sajal Kherde
Membro da: 02/16/16
107 Reputazione
1 Guida realizzata
IUPUI, Team 3-3, Harley Spring 2016 Membro di IUPUI, Team 3-3, Harley Spring 2016
IUPUI-HARLEY-S16S3G3
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 8
Tutti i Tempi: 649
