Salta al contenuto principale
AYL SoundFit Battery Replacement
Cosa ti serve
  1. AYL SoundFit Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Remove the four hex screws on the top of the device using a 2.5 hex screwdriver.
  2. AYL SoundFit Battery Replacement: passo 2, immagine 1 di 1
    • Place a spudger between the black plastic cover and the green case.
    • Pry the black cover away from the main casing and remove the cover.
  3. AYL SoundFit Battery Replacement: passo 3, immagine 1 di 1
    • Place a spudger between the black housing, which contains the woofer, and the outer rubber casing.
    • Pry the housing away from the body to reveal the motherboard, speaker, and battery.
  4. AYL SoundFit Battery Replacement: passo 4, immagine 1 di 2 AYL SoundFit Battery Replacement: passo 4, immagine 2 di 2
    • Remove the two Phillips #00 screws securing the battery casing.
    • Remove the battery case to reveal the battery.
  5. AYL SoundFit Battery Replacement: passo 5, immagine 1 di 1
    • Desolder the positive and negative battery contacts from the motherboard.
    • Remove the battery from the device.
Conclusione
Dustin Moore
Membro da: 02/16/16
108 Reputazione
1 Guida realizzata
IUPUI, Team 3-3, Harley Spring 2016 Membro di IUPUI, Team 3-3, Harley Spring 2016
IUPUI-HARLEY-S16S3G3
4 Membri
5 Guide realizzate
4Commenti sulla guida
Which battery is this, and what is the mAH?
jlongsa - Replica
3.7V 1500mAh, 5.55Wh
Coba Farr -
The charger works but it does not say chargeing
Zaira Cortes - Replica
18650 battery
rich4349 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 18
Tutti i Tempi: 3,050
