Salta al contenuto principale
AUX-208P1 Electric Kettle Temperature Controller Replacement
Cosa ti serve
  1. AUX-208P1 Electric Kettle Temperature Controller Replacement, Temperature Controller: passo 1, immagine 1 di 2 AUX-208P1 Electric Kettle Temperature Controller Replacement, Temperature Controller: passo 1, immagine 2 di 2
    • Clean all the dirt on the bottom of the electric kettle.
  2. AUX-208P1 Electric Kettle Temperature Controller Replacement: passo 2, immagine 1 di 2 AUX-208P1 Electric Kettle Temperature Controller Replacement: passo 2, immagine 2 di 2
    • Use a Phillips #0 screwdriver to remove the three 19 mm screws at the bottom of the electric kettle.
    • Remove the base of the electric kettle.
    • Remove the LED indicator buckled on the base.
  3. AUX-208P1 Electric Kettle Temperature Controller Replacement: passo 3, immagine 1 di 2 AUX-208P1 Electric Kettle Temperature Controller Replacement: passo 3, immagine 2 di 2
    • Use combination pliers to clamp the connection between the electric kettle line and the old temperature controller to create a gap, and pull it off.
    • Don't use too much force to avoid damage to the line!
  4. AUX-208P1 Electric Kettle Temperature Controller Replacement: passo 4, immagine 1 di 1
    • Use combination pliers to remove the nuts holding down the old temperature controller.
  5. AUX-208P1 Electric Kettle Temperature Controller Replacement: passo 5, immagine 1 di 2 AUX-208P1 Electric Kettle Temperature Controller Replacement: passo 5, immagine 2 di 2
    • Remove the broken temperature controller.
    • Clean the bottom of the kettle to remove any dust or debris buildup.
  6. AUX-208P1 Electric Kettle Temperature Controller Replacement: passo 6, immagine 1 di 1
    • Align the socket on the bottom of the new temperature controller with the protrusion on the bottom of the electric kettle to assemble.
  7. AUX-208P1 Electric Kettle Temperature Controller Replacement: passo 7, immagine 1 di 1
    • Use combination pliers to reinstall the nuts holding down the temperature controller.
  8. AUX-208P1 Electric Kettle Temperature Controller Replacement: passo 8, immagine 1 di 1
    • Fasten the electric kettle circuit to the contact reed of the new temperature controller.
    • Gently pull the interface to ensure a firm installation.
  9. AUX-208P1 Electric Kettle Temperature Controller Replacement: passo 9, immagine 1 di 2 AUX-208P1 Electric Kettle Temperature Controller Replacement: passo 9, immagine 2 di 2
    • Re-buckle the removed LED indicator back to the base.
    • Buckle the base back to the bottom of the electric kettle.
    • Use a Phillips #0 screwdriver to three 19 mm screws on the bottom of the kettle.
Conclusione
重新组装设备时,请依次相反的拆卸顺序。
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 61
Tutti i Tempi: 1,279
