Salta al contenuto principale
ATT Trek HD9020A Motherboard Replacement
Cosa ti serve
  1. ATT Trek HD9020A Motherboard Replacement, Back Cover: passo 1, immagine 1 di 1
    • To separate the screen from the back panel, run the plastic opening tool along the outer edge of the device.
  2. ATT Trek HD9020A Motherboard Replacement: passo 2, immagine 1 di 1
    • Pull the screen away from the back panel.
  3. ATT Trek HD9020A Motherboard Replacement, Battery: passo 3, immagine 1 di 2 ATT Trek HD9020A Motherboard Replacement, Battery: passo 3, immagine 2 di 2
    • Use a Phillips #00 screwdriver to remove the six 2.5 mm screws located around the perimeter of the battery.
  4. ATT Trek HD9020A Motherboard Replacement: passo 4, immagine 1 di 2 ATT Trek HD9020A Motherboard Replacement: passo 4, immagine 2 di 2
    • Use the plastic opening tool to disconnect the black battery connector.
    • Gently lift the battery out of the device.
  5. ATT Trek HD9020A Motherboard Replacement, Motherboard: passo 5, immagine 1 di 2 ATT Trek HD9020A Motherboard Replacement, Motherboard: passo 5, immagine 2 di 2
    • Using a Phillips #00 screwdriver, remove the seven 1 mm screws on the green perimeter of the motherboard.
  6. ATT Trek HD9020A Motherboard Replacement: passo 6, immagine 1 di 2 ATT Trek HD9020A Motherboard Replacement: passo 6, immagine 2 di 2
    • Use the plastic opening tool to disconnect the large gold strip underneath the metal plate from the motherboard.
  7. ATT Trek HD9020A Motherboard Replacement: passo 7, immagine 1 di 1
    • Use the plastic opening tool to disconnect the front and back cameras from motherboard.
  8. ATT Trek HD9020A Motherboard Replacement: passo 8, immagine 1 di 2 ATT Trek HD9020A Motherboard Replacement: passo 8, immagine 2 di 2
    • Use angled tweezers to pry up the black tab.
    • Use the angled tweezers to pull out the gold connector.
  9. ATT Trek HD9020A Motherboard Replacement: passo 9, immagine 1 di 2 ATT Trek HD9020A Motherboard Replacement: passo 9, immagine 2 di 2
    • Use the angled tweezers to disconnect the gold connector.
  10. ATT Trek HD9020A Motherboard Replacement: passo 10, immagine 1 di 1
    • Use the plastic opening tool to disconnect the black connectors on each side of the motherboard.
  11. ATT Trek HD9020A Motherboard Replacement: passo 11, immagine 1 di 2 ATT Trek HD9020A Motherboard Replacement: passo 11, immagine 2 di 2
    • Use the plastic opening tool to lift the motherboard out of place.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 168
