Introduzione
This guide will show how to replace the screen digitizer in the device. This repair might be needed if the screen is not lit properly, or is showing dead pixels on the screen. The tools that will be needed in order to replace this part are the blue plastic opening tool, thePhillips #00 screwdriver, and the angled tweezers. When replacing this part, the motherboard has to be removed.
Cosa ti serve
To separate the screen from the back panel, run the plastic opening tool along the outer edge of the device.
Use a Phillips #00 screwdriver to remove the six 2.5 mm screws located around the perimeter of the battery.
Using a Phillips #00 screwdriver, remove the seven 1 mm screws on the green perimeter of the motherboard.
Use the Phillips #00 screwdriver to remove the six 3 mm screws holding the black plastic corner pieces in place.
Gently lift the black corner pieces out of the device.
Use the plastic opening tool to pry the charging board away from the digitizer.
