Salta al contenuto principale
ATT EL52300 Battery Replacement
  1. ATT EL52300 Battery Replacement, Battery: passo 1, immagine 1 di 2 ATT EL52300 Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Find the bump where the battery cover meets the phone. Put your thumb here, and push and slide the cover down.
  2. ATT EL52300 Battery Replacement: passo 2, immagine 1 di 1
    • Unplug the battery by squeezing your hands on the small white plug and lifting it up.
    • Do not pull on the wire itself because you might damage the wire!
    • The battery is now detached and ready to be removed by lifting it out.
Conclusione
Katty
Membro da: 08/27/15
313 Reputazione
3 Guide realizzate
USF Tampa, Team 1-1, Sullivan Spring 2016 Membro di USF Tampa, Team 1-1, Sullivan Spring 2016
USFT-SULLIVAN-S16S1G1
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 11
Tutti i Tempi: 887
