Salta al contenuto principale
ATT CL4940 Internal Speaker Replacement
Cosa ti serve
  1. ATT CL4940 Internal Speaker Replacement, Internal Speaker: passo 1, immagine 1 di 2 ATT CL4940 Internal Speaker Replacement, Internal Speaker: passo 1, immagine 2 di 2
    • Unplug your device before beginning disassembly.
    • Remove phone line and power cord from the back cover of the device.
    • Remove phone cable from the side of the device.
  2. ATT CL4940 Internal Speaker Replacement: passo 2, immagine 1 di 1
    • Remove the five 4mm X 10mm Phillips head screws from the back cover of the device.
  3. ATT CL4940 Internal Speaker Replacement: passo 3, immagine 1 di 3 ATT CL4940 Internal Speaker Replacement: passo 3, immagine 2 di 3 ATT CL4940 Internal Speaker Replacement: passo 3, immagine 3 di 3
    • Starting from the bottom of the device, use a metal spudger, separate the top (white) plastic piece from the bottom (gray) plastic piece.
    • Work your way across the bottom of the device, then to each side, and finally to the top.
    • There are brackets every few inches along the edge of the device. These may be difficult to pull apart.
    • The top and bottom pieces should separate, and the internals of the device will now be accessible.
  4. ATT CL4940 Internal Speaker Replacement: passo 4, immagine 1 di 1
    • Using wire cutters, sever both the red and black wires connected to the speaker.
    • Carefully remove the speaker from the assembly.
    • Be sure to remove the rubber gasket from the broken speaker. You will need this for reassembly.
Conclusione
Charles Moore
Membro da: 02/16/16
201 Reputazione
2 Guide realizzate
IUPUI, Team 2-2, Harley Spring 2016 Membro di IUPUI, Team 2-2, Harley Spring 2016
IUPUI-HARLEY-S16S2G2
4 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 11
Tutti i Tempi: 392
