Salta al contenuto principale
ATT CL4940 Internal Microphone Replacement
Cosa ti serve
  1. ATT CL4940 Internal Microphone Replacement, Internal Microphone: passo 1, immagine 1 di 2 ATT CL4940 Internal Microphone Replacement, Internal Microphone: passo 1, immagine 2 di 2
    • Unplug your device before beginning disassembly.
    • Remove the phone line and the power cord from the back of the device.
    • Remove the phone cable from the side of the device.
  2. ATT CL4940 Internal Microphone Replacement: passo 2, immagine 1 di 1
    • Remove the five 4mm X 10mm Phillips head screws from the back cover of the device.
  3. ATT CL4940 Internal Microphone Replacement: passo 3, immagine 1 di 3 ATT CL4940 Internal Microphone Replacement: passo 3, immagine 2 di 3 ATT CL4940 Internal Microphone Replacement: passo 3, immagine 3 di 3
    • Starting from the bottom of the device, (using a metal spudger) separate the top (white) plastic piece from the bottom (gray) plastic piece.
    • Work your way across the bottom of the device, then to each side, and finally to the top.
    • There are brackets every few inches along the edge of the device. These may be difficult to pull apart.
    • The top and bottom pieces should separate, and the internals of the device will now be accessible.
  4. ATT CL4940 Internal Microphone Replacement: passo 4, immagine 1 di 1
    • Using wire cutters, sever both the red and the black wires connected to the microphone.
    • To remove the microphone from the device, gently wiggle it while pulling it apart.
Conclusione
Charles Moore
Membro da: 02/16/16
201 Reputazione
2 Guide realizzate
IUPUI, Team 2-2, Harley Spring 2016 Membro di IUPUI, Team 2-2, Harley Spring 2016
IUPUI-HARLEY-S16S2G2
4 Membri
8 Guide realizzate
Un commento
I'd rather install a new microphone instead of just reinstalling the old one.
Is there a link to where a new microphone can be purchased?
rpoland - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 17
Tutti i Tempi: 645
