Salta al contenuto principale
AT-LP60X Setup Guide
  1. AT-LP60X Setup Guide, Place Turntable: passo 1, immagine 1 di 2 AT-LP60X Setup Guide, Place Turntable: passo 1, immagine 2 di 2
    • Place your turntable on a clear, flat surface.
    • Ensure there is no power connected to the turntable at this time.
  2. AT-LP60X Setup Guide, Locate and Install Platter/Belt: passo 2, immagine 1 di 1
    • Obtain the silver metal platter.
    • Verify that the belt is installed around the inner ring of the platter.
  3. AT-LP60X Setup Guide, Install Platter: passo 3, immagine 1 di 2 AT-LP60X Setup Guide, Install Platter: passo 3, immagine 2 di 2
    • Place the platter on the center spindle.
    • Rotate the platter to show the gold pulley of the motor.
    • Stretch the belt from the platter over the gold pulley of the motor.
  4. AT-LP60X Setup Guide, Preform Mechanical Reset: passo 4, immagine 1 di 2 AT-LP60X Setup Guide, Preform Mechanical Reset: passo 4, immagine 2 di 2
    • Place the slipmat on top of the platter and press the STOP button.
    • With your right hand, hold the tone arm in place.
    • [OPTIONAL] use the included hook and twist tie for this step.
    • With your left hand, rotate the platter clockwise about 10 times.
    • You should hear a series of clicks and pops.
  5. AT-LP60X Setup Guide, Reconnect Turntable: passo 5, immagine 1 di 1
    • Reconnect the power supply.
    • Connect the 3.5mm to RCA to your speakers.
    • For powered speakers the output switch should be in "LINE", if connecting to an amp/phono input the output should be in "PHONO"
    • The output switch position does not matter if you are connecting to a Bluetooth speaker.
  6. AT-LP60X Setup Guide, Prepare Tonearm: passo 6, immagine 1 di 3 AT-LP60X Setup Guide, Prepare Tonearm: passo 6, immagine 2 di 3 AT-LP60X Setup Guide, Prepare Tonearm: passo 6, immagine 3 di 3
    • Remove the clear plastic cover from the stylus (if present) by sliding the COVER ONLY directly towards the front of the turntable.
    • Unsecure the twist tie from the built-in hook (if present).
    • Ensure the tone arm lift button is in the outward position.
    • The setup is now complete and you are ready to try a record!
Conclusione
If you have any trouble setting up your turntable and/or a new problem arises, feel free to contact a technician at (330)686-2600 ext.5004 or service@atus.com
Anthony @ ATUS
Membro da: 02/28/19
1.045 Reputazione
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 34
Tutti i Tempi: 34
