Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Introduzione
The ASUS ZenWatch comes with a leather strap that will wear down and need replacing. Any 22mm watch strap can be easily installed using these steps.
If replacing with a generic strap make sure it comes with 22mm spring bars!
  1. On the strap there is a knob. Sliding this knob towards the opposite side of the strap releases the tension on the spring bar, allowing you to pull the strap out.. On the strap there is a knob. Sliding this knob towards the opposite side of the strap releases the tension on the spring bar, allowing you to pull the strap out..
    • On the strap there is a knob. Sliding this knob towards the opposite side of the strap releases the tension on the spring bar, allowing you to pull the strap out..
Conclusione
Wayne McClure
Membro da: 10/02/2016
952 Reputazione
5 Guide realizzate
USF Tampa, Team 1-3, Sullivan Spring 2016 Membro di USF Tampa, Team 1-3, Sullivan Spring 2016
USFT-SULLIVAN-S16S1G3
4 Membri
7 Guide realizzate
My only comment is that I am a electronic and gadget geek I also want to learn how to work on them
larry curry - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 8
Tutti i Tempi: 864
