Introduzione
Step-by-step guide in removing and replacing a faulty motherboard.
Cosa ti serve
On the strap there is a knob. Sliding this knob towards the opposite side of the strap releases the tension on the spring bar, allowing you to pull the strap out..
Use the T5 Torx driver to remove the four screws on the case.
The case will pry easily off with just gentle hand pressure
With the metal tweezers gently remove the fabric covering the connection on bottom right
Using the heavy duty plastic spudger pry up on the connection ribbon.
Altre 3 persone hanno completato questa guida.
Un commento
Where could i get the new replacement motherboard for that? Please inform.. thanks :)
