Salta al contenuto principale
ASUS ZenWatch Charging Cradle Circuit board Replacement
Cosa ti serve
  1. ASUS ZenWatch Charging Cradle Circuit board Replacement, Charging Cradle Circuit board: passo 1, immagine 1 di 3 ASUS ZenWatch Charging Cradle Circuit board Replacement, Charging Cradle Circuit board: passo 1, immagine 2 di 3 ASUS ZenWatch Charging Cradle Circuit board Replacement, Charging Cradle Circuit board: passo 1, immagine 3 di 3
    • Using a metal spudger gently pry the plastic outer case apart
    • Pry open a little bit on each side before trying to open fully
  2. ASUS ZenWatch Charging Cradle Circuit board Replacement: passo 2, immagine 1 di 3 ASUS ZenWatch Charging Cradle Circuit board Replacement: passo 2, immagine 2 di 3 ASUS ZenWatch Charging Cradle Circuit board Replacement: passo 2, immagine 3 di 3
    • Use the PH0 sized Phillips screwdriver to remove the three screws (2mm) holding the board to the cradle.
    • Gently pry up with your hands to pull the board off.
    • Don't grab directly on the USB port as you may loosen or bust the connections.
Conclusione
USF Tampa, Team 1-3, Sullivan Spring 2016 Membro di USF Tampa, Team 1-3, Sullivan Spring 2016
USFT-SULLIVAN-S16S1G3
4 Membri
7 Guide realizzate
Un commento
If you had listed what components were on the board or at least taken a picture of the other side of the board, I might have given you some points.
Nate Fansler - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 2,833
