Salta al contenuto principale
ASUS ZenPad S 8.0 Motherboard Replacement
Cosa ti serve
  1. ASUS ZenPad S 8.0 Motherboard Replacement, Rear Cover Removal: passo 1, immagine 1 di 3 ASUS ZenPad S 8.0 Motherboard Replacement, Rear Cover Removal: passo 1, immagine 2 di 3 ASUS ZenPad S 8.0 Motherboard Replacement, Rear Cover Removal: passo 1, immagine 3 di 3
    • if present, remove the MicroSD card before disassembly. Failure to remove could lead to damage to the MicroSD card , rear cover, or MicroSD card slot.
    • Use the plastic tool to pry between the silver bezel and the back case
    • Work the tool around the device to free the back case
  2. ASUS ZenPad S 8.0 Motherboard Replacement: passo 2, immagine 1 di 2 ASUS ZenPad S 8.0 Motherboard Replacement: passo 2, immagine 2 di 2
    • Remove the ribbon cables by lifting up the white retaining flap on the ZIF connectors, then pulling the ribbon cable away.
    • Do not kink the ribbon cables as they can break easily
  3. ASUS ZenPad S 8.0 Motherboard Replacement: passo 3, immagine 1 di 3 ASUS ZenPad S 8.0 Motherboard Replacement: passo 3, immagine 2 di 3 ASUS ZenPad S 8.0 Motherboard Replacement: passo 3, immagine 3 di 3
    • Remove the battery connector by prying it up away from the device using 2 plastic pry tools
  4. ASUS ZenPad S 8.0 Motherboard Replacement: passo 4, immagine 1 di 2 ASUS ZenPad S 8.0 Motherboard Replacement: passo 4, immagine 2 di 2
    • Remove all 9 of the 1.5mm #00 Philips screws
    • Gently lift the battery out of the device
    • Use an opening pick or similar tool to separate the adhesive on the bottom and top of the battery.
  5. ASUS ZenPad S 8.0 Motherboard Replacement, Front Facing Camera: passo 5, immagine 1 di 3 ASUS ZenPad S 8.0 Motherboard Replacement, Front Facing Camera: passo 5, immagine 2 di 3 ASUS ZenPad S 8.0 Motherboard Replacement, Front Facing Camera: passo 5, immagine 3 di 3
    • Use a plastic opening tool to lift the black retaining flap on the ZIF Connector
  6. ASUS ZenPad S 8.0 Motherboard Replacement: passo 6, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Use a tweezers to lift out the camera
    • If you lifted the latch for the ribbon cable then it should come out with little resistance.
  7. ASUS ZenPad S 8.0 Motherboard Replacement, Motherboard: passo 7, immagine 1 di 2 ASUS ZenPad S 8.0 Motherboard Replacement, Motherboard: passo 7, immagine 2 di 2
    • Using the plastic prying tool, lift the small retaining flap on the ZIF Connectors holding the ribbon cables to the motherboard
    • The removing of the ribbon cable is done in the same way as the front facing camera.
  8. ASUS ZenPad S 8.0 Motherboard Replacement: passo 8, immagine 1 di 3 ASUS ZenPad S 8.0 Motherboard Replacement: passo 8, immagine 2 di 3 ASUS ZenPad S 8.0 Motherboard Replacement: passo 8, immagine 3 di 3
    Compra
    • Using the tweezers remove the connector gently from the yellow slot
    • Gently peel up the tape until is is completely released from the motherboard
  9. ASUS ZenPad S 8.0 Motherboard Replacement: passo 9, immagine 1 di 2 ASUS ZenPad S 8.0 Motherboard Replacement: passo 9, immagine 2 di 2
    • Cut the warranty tape connecting the motherboard to the metal plate under the battery
  10. ASUS ZenPad S 8.0 Motherboard Replacement: passo 10, immagine 1 di 1
    • Using the #00 Phillips head screwdriver, remove the remaining 1.5mm screws in the motherboard
  11. ASUS ZenPad S 8.0 Motherboard Replacement: passo 11, immagine 1 di 1
    • Gently lift the motherboard from your device
Conclusione
USF Tampa, Team 2-2, Cagle Fall 2016 Membro di USF Tampa, Team 2-2, Cagle Fall 2016
USFT-CAGLE-F16S2G2
4 Membri
5 Guide realizzate
2 Commenti
Where can I buy a spare motherboard for this device.
Partha Tripathy - Replica
Where are the motherboard sold and how do I purchase micro USB ports
Xibu Zhang - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 11
Tutti i Tempi: 2,604
