Salta al contenuto principale
ASUS ZENFONE 3 Zoom Front Camera Replacement
Cosa ti serve
  1. ASUS ZENFONE 3 Zoom Front Camera Replacement, Battery: passo 1, immagine 1 di 2 ASUS ZENFONE 3 Zoom Front Camera Replacement, Battery: passo 1, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Using a pair of tweezers, pull put the SIM card tray and set it to the side.
  2. ASUS ZENFONE 3 Zoom Front Camera Replacement: passo 2, immagine 1 di 1
    • Remove the two 2 mm screws using a Torx T2 screwdriver.
  3. ASUS ZENFONE 3 Zoom Front Camera Replacement: passo 3, immagine 1 di 2 ASUS ZENFONE 3 Zoom Front Camera Replacement: passo 3, immagine 2 di 2
    • Insert a prying tool between the screen and the metal backing of the phone at the bottom to remove backing from phone.
    • There will be a thin film connecting the two pieces. You do not need to remove this. Just fold the two pieces apart with the inside facing up.
  4. ASUS ZENFONE 3 Zoom Front Camera Replacement: passo 4, immagine 1 di 1
    • Remove the two 3 mm screws, using the Phillips #00 screwdriver, on the silver band at the top of the battery and remove the band.
  5. ASUS ZENFONE 3 Zoom Front Camera Replacement: passo 5, immagine 1 di 1
    • Peel back the silver tape.
  6. ASUS ZENFONE 3 Zoom Front Camera Replacement: passo 6, immagine 1 di 1
    • Disconnect the battery connections.
  7. ASUS ZENFONE 3 Zoom Front Camera Replacement: passo 7, immagine 1 di 1
    • Pry and remove the battery.
    • The underside of the battery is adhesive so make sure to pry the battery off gently.
  8. ASUS ZENFONE 3 Zoom Front Camera Replacement, Front Camera: passo 8, immagine 1 di 1
    • Peel the copper adhesive off.
  9. ASUS ZENFONE 3 Zoom Front Camera Replacement: passo 9, immagine 1 di 3 ASUS ZENFONE 3 Zoom Front Camera Replacement: passo 9, immagine 2 di 3 ASUS ZENFONE 3 Zoom Front Camera Replacement: passo 9, immagine 3 di 3
    • Unplug the front camera.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 9
Tutti i Tempi: 566
