Salta al contenuto principale
ASUS X552LAV-BBI5N08 Hard Drive Replacement
Cosa ti serve
  1. ASUS X552LAV-BBI5N08 Hard Drive Replacement, Battery: passo 1, immagine 1 di 1
    • Battery is not showed in pictures.
    • Flip the laptop face down.
  2. ASUS X552LAV-BBI5N08 Hard Drive Replacement: passo 2, immagine 1 di 3 ASUS X552LAV-BBI5N08 Hard Drive Replacement: passo 2, immagine 2 di 3 ASUS X552LAV-BBI5N08 Hard Drive Replacement: passo 2, immagine 3 di 3
    • Slide the right button to the left.
    • Hold the left button to the right.
    • While you hold the left button in position, slide the battery out by pushing it away from you.
  3. ASUS X552LAV-BBI5N08 Hard Drive Replacement, Hard Drive: passo 3, immagine 1 di 1
    • Start by flipping the laptop face down.
    • Locate the bottom panel. It is at the opposite end of the battery.
    • Remove the two 12mm screws at the bottom panel with a Tri-wing Y1 screwdriver.
  4. ASUS X552LAV-BBI5N08 Hard Drive Replacement: passo 4, immagine 1 di 3 ASUS X552LAV-BBI5N08 Hard Drive Replacement: passo 4, immagine 2 di 3 ASUS X552LAV-BBI5N08 Hard Drive Replacement: passo 4, immagine 3 di 3
    • Remove bottom panel by lifting it up.
    • Locate the hard drive.
    • It is located in the bottom left corner.
  5. ASUS X552LAV-BBI5N08 Hard Drive Replacement: passo 5, immagine 1 di 3 ASUS X552LAV-BBI5N08 Hard Drive Replacement: passo 5, immagine 2 di 3 ASUS X552LAV-BBI5N08 Hard Drive Replacement: passo 5, immagine 3 di 3
    • Remove the four 5.5mm screws located on the hard drive case using a Tri-wing Y1 screwdriver.
    • Slide the hard drive out to the left.
  6. ASUS X552LAV-BBI5N08 Hard Drive Replacement: passo 6, immagine 1 di 2 ASUS X552LAV-BBI5N08 Hard Drive Replacement: passo 6, immagine 2 di 2
    • Lift the hard drive out.
    • Once the hard drive is removed, place the hard drive at a different area.
  7. ASUS X552LAV-BBI5N08 Hard Drive Replacement: passo 7, immagine 1 di 3 ASUS X552LAV-BBI5N08 Hard Drive Replacement: passo 7, immagine 2 di 3 ASUS X552LAV-BBI5N08 Hard Drive Replacement: passo 7, immagine 3 di 3
    • Place the hard drive on its side.
    • Remove the four 5mm screws from the sides of the case by using a Tri-wing Y1 screwdriver.
    • Lift the hard drive out of the case.
Conclusione
Jason Vo
Membro da: 02/15/18
857 Reputazione
5 Guide realizzate
USF Tampa, Team S17-G1, Boczar Spring 2018 Membro di USF Tampa, Team S17-G1, Boczar Spring 2018
USFT-BOCZAR-S18S17G1
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 12
Tutti i Tempi: 297
