Introduzione
The motherboard is a large, crucial component of the laptop that communicates with the rest of the components and controls most of the major functions. As such, it is also known as the heart of the laptop.
Cosa ti serve
Place the laptop on a flat surface with the bottom side facing upwards.
Using the Phillips #1 Screwdriver, remove the four 4mm screws in the back panel.
Using both hands, slide the back panel away from the laptop horizontally.
Flip the motherboard to show the underside.
Locate the two square connections attached to the motherboard.
Disconnect them using blunt tweezers.
Altre 3 persone hanno completato questa guida.
