Salta al contenuto principale
ASUS X533SA-BHCLN10 LCD Screen Replacement
Cosa ti serve
Panoramica Video
  1. ASUS X533SA-BHCLN10 LCD Screen Replacement, LCD Screen: passo 1, immagine 1 di 2 ASUS X533SA-BHCLN10 LCD Screen Replacement, LCD Screen: passo 1, immagine 2 di 2
    • Power off laptop.
    • Flip over the laptop so the model stickers are pointing towards the ceiling, and the back of the laptop is facing you.
  2. ASUS X533SA-BHCLN10 LCD Screen Replacement: passo 2, immagine 1 di 3 ASUS X533SA-BHCLN10 LCD Screen Replacement: passo 2, immagine 2 di 3 ASUS X533SA-BHCLN10 LCD Screen Replacement: passo 2, immagine 3 di 3
    • Carefully insert a plastic opening tool into the top edge of the plastic cover. Slowly run the tool along the top edge to allow several small plastic clips to release.
    • Lift the plastic cover off and set it aside.
  3. ASUS X533SA-BHCLN10 LCD Screen Replacement: passo 3, immagine 1 di 3 ASUS X533SA-BHCLN10 LCD Screen Replacement: passo 3, immagine 2 di 3 ASUS X533SA-BHCLN10 LCD Screen Replacement: passo 3, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    • Using tweezers, remove the (2) two magnetic tabs covering the screws on the screen.
  4. ASUS X533SA-BHCLN10 LCD Screen Replacement: passo 4, immagine 1 di 3 ASUS X533SA-BHCLN10 LCD Screen Replacement: passo 4, immagine 2 di 3 ASUS X533SA-BHCLN10 LCD Screen Replacement: passo 4, immagine 3 di 3
    • Use a JIS #0 screwdriver to remove the two 4.5mm screws.
  5. ASUS X533SA-BHCLN10 LCD Screen Replacement: passo 5, immagine 1 di 2 ASUS X533SA-BHCLN10 LCD Screen Replacement: passo 5, immagine 2 di 2
    • Insert a plastic opening tool under the edge of the laptop lid.
    • Carefully pop out the sides of the laptop by running the plastic opening tool along the edge.
  6. ASUS X533SA-BHCLN10 LCD Screen Replacement: passo 6, immagine 1 di 2 ASUS X533SA-BHCLN10 LCD Screen Replacement: passo 6, immagine 2 di 2
    • Use a JIS #0 screwdriver to unscrew the four 3.5mm screws.
  7. ASUS X533SA-BHCLN10 LCD Screen Replacement: passo 7, immagine 1 di 3 ASUS X533SA-BHCLN10 LCD Screen Replacement: passo 7, immagine 2 di 3 ASUS X533SA-BHCLN10 LCD Screen Replacement: passo 7, immagine 3 di 3
    • Carefully lift up the LCD screen.
    • Carefully remove the cable connecting the LCD to the laptop by popping up the white clip on the laptop and sliding the connector out.
Conclusione
Spencer Lee
Membro da: 11/01/18
283 Reputazione
2 Guide realizzate
IUPUI, Team S2-G4, Harley Fall 2018 Membro di IUPUI, Team S2-G4, Harley Fall 2018
IUPUI-HARLEY-F18S2G4
3 Membri
2 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 11
Tutti i Tempi: 631
