Salta al contenuto principale
ASUS X533SA-BHCLN10 Battery Replacement
Cosa ti serve
  1. ASUS X533SA-BHCLN10 Battery Replacement, Battery: passo 1, immagine 1 di 2 ASUS X533SA-BHCLN10 Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Turn over the laptop on the back panel.
    • Use the Phillips #0 screwdriver to unscrew all ten screws visible on the back panel. There should be a total of ten screws: (4) four 5.5mm screws and (6) six 10.5mm screws.
  2. ASUS X533SA-BHCLN10 Battery Replacement: passo 2, immagine 1 di 2 ASUS X533SA-BHCLN10 Battery Replacement: passo 2, immagine 2 di 2
    • Turn over the laptop with the keyboard facing upwards.
    • Using a small prying or opening tool, stick the prying tool under the edge of the laptop.
  3. ASUS X533SA-BHCLN10 Battery Replacement: passo 3, immagine 1 di 2 ASUS X533SA-BHCLN10 Battery Replacement: passo 3, immagine 2 di 2
    • After the laptop is completely pried open carefully remove the keyboard from the laptop.
    • There are two small keyboard cables connecting the keyboard to the laptop. Carefully remove these by popping up the white clips holding them in place and slide the connector out.
Conclusione
Altre 3 persone hanno completato questa guida.
Edmund Lee
Membro da: 09/26/17
473 Reputazione
4 Guide realizzate
USF Tampa, Team S13-G3, Boczar Fall 2017 Membro di USF Tampa, Team S13-G3, Boczar Fall 2017
USFT-BOCZAR-F17S13G3
5 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 6
Tutti i Tempi: 634
