Salta al contenuto principale
ASUS X502CA Left I/O Board Replacement
Cosa ti serve
  1. ASUS X502CA Left I/O Board Replacement, Palm Rest with Keyboard and Touch Pad: passo 1, immagine 1 di 1
    • Use the Phillips #00 screwdriver to remove the seven 90mm screws.
    • Use the Phillips #00 screwdriver to remove the four 50mm screws.
  2. ASUS X502CA Left I/O Board Replacement: passo 2, immagine 1 di 1
    • Next, use the plastic opening tool to carefully pop off the keyboard cover panel.
    • Be cautious when pulling off the cover because there are cables you will have to disconnect before completely removing the panel.
  3. ASUS X502CA Left I/O Board Replacement: passo 3, immagine 1 di 2 ASUS X502CA Left I/O Board Replacement: passo 3, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Lift palm rest and unplug keyboard cable and touchpad cable using tweezers. After these two cables have been unplugged you can remove the keyboard cover panel.
  4. ASUS X502CA Left I/O Board Replacement: passo 4, immagine 1 di 2 ASUS X502CA Left I/O Board Replacement: passo 4, immagine 2 di 2
    • Lift Palm Rest away.
    • Replace with new palm rest.
  5. ASUS X502CA Left I/O Board Replacement, Left I/O Board: passo 5, immagine 1 di 2 ASUS X502CA Left I/O Board Replacement, Left I/O Board: passo 5, immagine 2 di 2
    • Locate the I/O board on the left of the computer. Using the Phillips #0 screwdriver, unscrew the three 5mm screws to unhinge the screen, which will free the board allowing it to be removed and replaced.
    • Be careful with handling your computer while one side is unhinged; mishandling or over pressuring the other hinge could cause damage to it or the screen.
  6. ASUS X502CA Left I/O Board Replacement: passo 6, immagine 1 di 2 ASUS X502CA Left I/O Board Replacement: passo 6, immagine 2 di 2
    • Unplug the power strip connecting to the motherboard with your fingers or plastic opening tool.
    • Make sure the power strip is disconnected before pulling the board out.
  7. ASUS X502CA Left I/O Board Replacement: passo 7, immagine 1 di 2 ASUS X502CA Left I/O Board Replacement: passo 7, immagine 2 di 2
    • Slightly pull the unhinged screen up to free the board and remove it.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 9
Tutti i Tempi: 196
