Salta al contenuto principale
ASUS X502CA Battery Replacement
Cosa ti serve
  1. ASUS X502CA Battery Replacement, Palm Rest with Keyboard and Touch Pad: passo 1, immagine 1 di 1
    • Use the Phillips #00 screwdriver to remove the seven 90mm screws.
    • Use the Phillips #00 screwdriver to remove the four 50mm screws.
    Chiedi a FixBot
  2. ASUS X502CA Battery Replacement: passo 2, immagine 1 di 1
    • Next, use the plastic opening tool to carefully pop off the keyboard cover panel.
    • Be cautious when pulling off the cover because there are cables you will have to disconnect before completely removing the panel.
    Chiedi a FixBot
  3. ASUS X502CA Battery Replacement: passo 3, immagine 1 di 2 ASUS X502CA Battery Replacement: passo 3, immagine 2 di 2
    Strumento utilizzato in questo passaggio:
    • Lift palm rest and unplug keyboard cable and touchpad cable using tweezers. After these two cables have been unplugged you can remove the keyboard cover panel.
    Chiedi a FixBot
  4. ASUS X502CA Battery Replacement: passo 4, immagine 1 di 2 ASUS X502CA Battery Replacement: passo 4, immagine 2 di 2
    • Lift Palm Rest away.
    • Replace with new palm rest.
    Chiedi a FixBot
  5. ASUS X502CA Battery Replacement, Battery: passo 5, immagine 1 di 1
    • Next, locate the battery in the front of laptop (closest to you).
    Chiedi a FixBot
  6. ASUS X502CA Battery Replacement: passo 6, immagine 1 di 1
    • Unplug the battery from the laptop in the upper right hand corner of the battery using tweezers.
    • If battery is not unplugged, motherboard may shock you.
    Chiedi a FixBot
  7. ASUS X502CA Battery Replacement: passo 7, immagine 1 di 2 ASUS X502CA Battery Replacement: passo 7, immagine 2 di 2
    • Use the Phillips #00 Screwdriver to carefully remove the 6 screws holding the battery in place.
    • Once you have removed all six screws carefully lift the battery out and dispose.
    • Each screw is 50 mm in length and 15 mm in diameter.
    Chiedi a FixBot
Conclusione
Altre 5 persone hanno completato questa guida.
Clemson, Team 14-1, Shirley Winter 2015 Membro di Clemson, Team 14-1, Shirley Winter 2015
CLEM-SHIRLEY-W15S14G1
5 Membri
5 guide realizzate
1Commento della guida
Thank you for posting this
SteveFFFFF 0 - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 11
Ultimi 30 giorni: 73
Tutti i Tempi: 15,167
