Salta al contenuto principale
ASUS X44H-BBR4 Keyboard Replacement
Cosa ti serve
  1. ASUS X44H-BBR4 Keyboard Replacement, Keyboard: passo 1, immagine 1 di 2 ASUS X44H-BBR4 Keyboard Replacement, Keyboard: passo 1, immagine 2 di 2
    • Open the laptop to show the keyboard.
  2. ASUS X44H-BBR4 Keyboard Replacement: passo 2, immagine 1 di 1
    • Look at the top row of the keyboard, you will see a space that has four latches holding the keyboard down.
    • The latches are located above the Esc key, the F5 key, between the F10 and F11 key and the Delete key.
  3. ASUS X44H-BBR4 Keyboard Replacement: passo 3, immagine 1 di 3 ASUS X44H-BBR4 Keyboard Replacement: passo 3, immagine 2 di 3 ASUS X44H-BBR4 Keyboard Replacement: passo 3, immagine 3 di 3
    • Don't pull too hard on the keys otherwise they may fall off.
    • Push the latch away from the keyboard using the spudger point.
    • While pushing the latches use a plastic opening tool and pull up on a key near it.
    • Continue along the rest of the keyboard until it is released at all four latches.
  4. ASUS X44H-BBR4 Keyboard Replacement: passo 4, immagine 1 di 2 ASUS X44H-BBR4 Keyboard Replacement: passo 4, immagine 2 di 2
    • Push the keyboard away from the mouse track pad to unlock the bottom from the base.
    • Do not pull too hard because there is a ribbon connecting to keyboard to the motherboard.
  5. ASUS X44H-BBR4 Keyboard Replacement: passo 5, immagine 1 di 2 ASUS X44H-BBR4 Keyboard Replacement: passo 5, immagine 2 di 2
    • Flip the keyboard over to reveal the back of it and what is underneath.
  6. ASUS X44H-BBR4 Keyboard Replacement: passo 6, immagine 1 di 3 ASUS X44H-BBR4 Keyboard Replacement: passo 6, immagine 2 di 3 ASUS X44H-BBR4 Keyboard Replacement: passo 6, immagine 3 di 3
    • Pull each end of the black ribbon cable piece towards the mouse track pad to unlock the ribbon connector piece.
    • Gently pull out the ribbon cable from the connector piece.
  7. ASUS X44H-BBR4 Keyboard Replacement: passo 7, immagine 1 di 1
    • Remove the keyboard completely.
Conclusione
Altre 4 persone hanno completato questa guida.
Kelly Merlo
Membro da: 10/14/15
500 Reputazione
2 Guide realizzate
UMass Dartmouth, Team 4-3, Catania Fall 2015 Membro di UMass Dartmouth, Team 4-3, Catania Fall 2015
UMASSD-CATANIA-F15S4G3
4 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 14
Tutti i Tempi: 1,175
