Salta al contenuto principale
ASUS X42J Laptop Fan Replacement
Cosa ti serve
  1. ASUS X42J Laptop Fan Replacement, Keyboard: passo 1, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Metal Spudger
    $2.99
    Compra
    • Make sure your device is unplugged and turned off before proceeding.
    • Using a Spudger, gently pry up the keyboard.
  2. ASUS X42J Laptop Fan Replacement: passo 2, immagine 1 di 2 ASUS X42J Laptop Fan Replacement: passo 2, immagine 2 di 2
    Nylon Tipped Tweezers
    Compra
    • Rotate the keyboard to face downward.
    • Pull out the blue wiring connection. Use tweezers to make it easier to remove.
  3. ASUS X42J Laptop Fan Replacement, Disk Drive: passo 3, immagine 1 di 1
    • Use the Phillips #0 screwdriver to remove the two screws on the back of the laptop.
  4. ASUS X42J Laptop Fan Replacement: passo 4, immagine 1 di 1
    • Slide the disk drive out of the device.
  5. ASUS X42J Laptop Fan Replacement, Motherboard: passo 5, immagine 1 di 3 ASUS X42J Laptop Fan Replacement, Motherboard: passo 5, immagine 2 di 3 ASUS X42J Laptop Fan Replacement, Motherboard: passo 5, immagine 3 di 3
    • Remove all screws located on the bottom plate of the laptop, beginning with the three located underneath the disc drive.
  6. ASUS X42J Laptop Fan Replacement: passo 6, immagine 1 di 2 ASUS X42J Laptop Fan Replacement: passo 6, immagine 2 di 2
    • Rotate the laptop until it is sitting face up and extract all screws exposed by removing the keyboard.
  7. ASUS X42J Laptop Fan Replacement: passo 7, immagine 1 di 2 ASUS X42J Laptop Fan Replacement: passo 7, immagine 2 di 2
    Metal Spudger
    $2.99
    Compra
    • Pull up on the front panel using the spudger until the front panel separates from the bottom panel.
  8. ASUS X42J Laptop Fan Replacement: passo 8, immagine 1 di 1
    • Unscrew and remove the marked screws.
  9. ASUS X42J Laptop Fan Replacement: passo 9, immagine 1 di 1
    • Separate the connectors.
  10. ASUS X42J Laptop Fan Replacement: passo 10, immagine 1 di 2 ASUS X42J Laptop Fan Replacement: passo 10, immagine 2 di 2
    • Remove the motherboard from the device.
  11. ASUS X42J Laptop Fan Replacement, Fan: passo 11, immagine 1 di 1
    • Unscrew the six screws using the Phillips #0 Screwdriver.
  12. ASUS X42J Laptop Fan Replacement: passo 12, immagine 1 di 1
    • Unplug the fan's wires from the motherboard.
  13. ASUS X42J Laptop Fan Replacement: passo 13, immagine 1 di 2 ASUS X42J Laptop Fan Replacement: passo 13, immagine 2 di 2
    • Remove the fan from the motherboard.
Conclusione
Ryan Pritchard
Membro da: 09/21/18
105 Reputazione
1 Guida realizzata
Un commento
First step is wrong; attempting to prise out the keyboard will damage it. First step should be to remove the screws which hold in the keyboard.
Kate Gregory - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 588
