Salta al contenuto principale
ASUS Vivobook S500CA Battery Replacement
Cosa ti serve
  1. ASUS Vivobook S500CA Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Turn the device over to where the back plate is facing up.
  2. ASUS Vivobook S500CA Battery Replacement: passo 2, immagine 1 di 1
    • Use a Philips Head PH1 screwdriver to remove 10 screws (3 1cm screws and 7 .5cm screws) around the perimeter of the back plate.
    • Place screws where they cannot be lost as they will be used to replace the back plate.
  3. ASUS Vivobook S500CA Battery Replacement: passo 3, immagine 1 di 1
    • Remove the back plate by lifting it straight up.
  4. ASUS Vivobook S500CA Battery Replacement: passo 4, immagine 1 di 1
    • Remove 9 (.5 cm) phillips screws around the edge of the battery.
  5. ASUS Vivobook S500CA Battery Replacement: passo 5, immagine 1 di 1
    • Lift up the battery to reveal the battery terminal.
  6. ASUS Vivobook S500CA Battery Replacement: passo 6, immagine 1 di 1
    • Unclip the battery terminal by prying straight up on the sides of the connector to release the clip.
Conclusione
Deric Huffman
Membro da: 01/17/17
101 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 12
Tutti i Tempi: 6,116
