Salta al contenuto principale
ASUS Vivobook Q301LA-BSI5T17 Memory Card Replacement
Cosa ti serve
  1. ASUS Vivobook Q301LA-BSI5T17 Memory Card Replacement, Back Case Housing: passo 1, immagine 1 di 1
    • Remove all ten 6mm Phillips #1 screws from the bottom of the computer chassis.
  2. ASUS Vivobook Q301LA-BSI5T17 Memory Card Replacement: passo 2, immagine 1 di 1
    • Carefully pry open the back cover from the laptop and place it to the side.
  3. ASUS Vivobook Q301LA-BSI5T17 Memory Card Replacement, Memory Card: passo 3, immagine 1 di 2 ASUS Vivobook Q301LA-BSI5T17 Memory Card Replacement, Memory Card: passo 3, immagine 2 di 2
    • Lift the perforated metal cover up from the motherboard to expose the memory cards.
  4. ASUS Vivobook Q301LA-BSI5T17 Memory Card Replacement: passo 4, immagine 1 di 2 ASUS Vivobook Q301LA-BSI5T17 Memory Card Replacement: passo 4, immagine 2 di 2
    • Once the cover is removed the RAM will be accessible.
    • Use your fingertips to pry out the metal guards outlining both of the sides of the memory card.
    • The RAM stick should then pop up to rest at an angle to the motherboard.
  5. ASUS Vivobook Q301LA-BSI5T17 Memory Card Replacement: passo 5, immagine 1 di 1
    • Using your fingertips, slide the memory card out from the plastic housing and remove it from the board.
    • Be sure to remove the card at the same angle at which it rests to avoid damaging the card or the contacts of the slot.
Conclusione
Mark Fanelli
Membro da: 04/09/19
97 Reputazione
1 Guida realizzata
IUPUI, Team S1-G2, Hovde Spring 2019 Membro di IUPUI, Team S1-G2, Hovde Spring 2019
IUPUI-HOVDE-S19S1G2
3 Membri
4 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 461
