Salta al contenuto principale
ASUS Vivobook Q301LA-BSI5T17 Fan/Heatsink Replacement
Cosa ti serve
  1. ASUS Vivobook Q301LA-BSI5T17 Fan/Heatsink Replacement, Back Case Housing: passo 1, immagine 1 di 1
    • Remove all ten 6mm Phillips #1 screws from the bottom of the computer chassis.
  2. ASUS Vivobook Q301LA-BSI5T17 Fan/Heatsink Replacement: passo 2, immagine 1 di 1
    • Carefully pry open the back cover from the laptop and place it to the side.
  3. ASUS Vivobook Q301LA-BSI5T17 Fan/Heatsink Replacement, Fan: passo 3, immagine 1 di 1
    • Remove three 5mm Phillips #1 screws that are holding the fan in place.
  4. ASUS Vivobook Q301LA-BSI5T17 Fan/Heatsink Replacement: passo 4, immagine 1 di 2 ASUS Vivobook Q301LA-BSI5T17 Fan/Heatsink Replacement: passo 4, immagine 2 di 2
    • Carefully unplug the fan cable from the motherboard using a spudger or plastic opening tool.
  5. ASUS Vivobook Q301LA-BSI5T17 Fan/Heatsink Replacement: passo 5, immagine 1 di 2 ASUS Vivobook Q301LA-BSI5T17 Fan/Heatsink Replacement: passo 5, immagine 2 di 2
    • Carefully use your hands to remove the fan by pulling it from the heatsink housing.
    • Do not use excessive force; there is a potential to break the plastic.
Conclusione
IUPUI, Team S1-G2, Hovde Spring 2019 Membro di IUPUI, Team S1-G2, Hovde Spring 2019
IUPUI-HOVDE-S19S1G2
3 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 302
