Salta al contenuto principale
ASUS VivoBook S400C Hard Drive Replacement
Cosa ti serve
  1. ASUS VivoBook S400C Hard Drive Replacement, Remove the Bottom Cover: passo 1, immagine 1 di 1
    • Flip the device over and remove the ten 5.7 mm screws with a Phillips #0 screwdriver.
  2. ASUS VivoBook S400C Hard Drive Replacement: passo 2, immagine 1 di 2 ASUS VivoBook S400C Hard Drive Replacement: passo 2, immagine 2 di 2
    • Use a spudger or your fingers to go around and lift the edges and release the back panel.
  3. ASUS VivoBook S400C Hard Drive Replacement, Disconnect the Battery: passo 3, immagine 1 di 1
    • Using a spudger, lift up the plug connecting the battery to the motherboard.
  4. ASUS VivoBook S400C Hard Drive Replacement, Battery: passo 4, immagine 1 di 1
    • With a Phillips #0 screwdriver, remove the four 5.7 mm screws holding the battery to the laptop.
  5. ASUS VivoBook S400C Hard Drive Replacement: passo 5, immagine 1 di 1
    • Carefully lift the battery up and out of the device.
  6. ASUS VivoBook S400C Hard Drive Replacement, Hard Drive: passo 6, immagine 1 di 1
    • Remove the three Phillips #0 screws holding the the hard drive in place:
    • Two 3.8 mm screws.
    • One 5.7 mm screw.
  7. ASUS VivoBook S400C Hard Drive Replacement: passo 7, immagine 1 di 1
    • Pull left and lift out the hard drive.
Conclusione
Tiana Curry
Membro da: 10/18/19
85 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 24
Tutti i Tempi: 2,001
