Salta al contenuto principale
ASUS VivoBook S300CA-BBI5T01 Wi-Fi Card Replacement
Cosa ti serve
  1. ASUS VivoBook S300CA-BBI5T01 Wi-Fi Card Replacement, Wi-Fi Card: passo 1, immagine 1 di 1
    • Place the laptop upside down so that the bottom panel is facing upwards.
  2. ASUS VivoBook S300CA-BBI5T01 Wi-Fi Card Replacement: passo 2, immagine 1 di 1
    • Unscrew the following 10 screws
    • Eight 5 mm Phillips head screws
    • Two 10 mm Phillips head screws
  3. ASUS VivoBook S300CA-BBI5T01 Wi-Fi Card Replacement: passo 3, immagine 1 di 1
    • Carefully peel the panel off of the bottom of the laptop.
  4. ASUS VivoBook S300CA-BBI5T01 Wi-Fi Card Replacement: passo 4, immagine 1 di 1
    • Remove the one 3 mm Phillips head screw holding the Wi-Fi card in place.
  5. ASUS VivoBook S300CA-BBI5T01 Wi-Fi Card Replacement: passo 5, immagine 1 di 1
    • Carefully slide the card out of its connection port by pulling it outward.
  6. ASUS VivoBook S300CA-BBI5T01 Wi-Fi Card Replacement: passo 6, immagine 1 di 1
    • Remove the black and white antenna cable connector wires by carefully pulling upwards on them.
    • Note that the black wire connects to "Main" and the white wire connects to "Aux".
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 5
Tutti i Tempi: 556
