Salta al contenuto principale
ASUS VivoBook S300CA-BBI5T01 Battery Replacement
Cosa ti serve
  1. ASUS VivoBook S300CA-BBI5T01 Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Place the laptop upside down so that the bottom panel is facing upwards.
  2. ASUS VivoBook S300CA-BBI5T01 Battery Replacement: passo 2, immagine 1 di 1
    • Unscrew the following 10 screws
    • Eight 5 mm Phillips head screws
    • Two 10 mm Phillips head screws
  3. ASUS VivoBook S300CA-BBI5T01 Battery Replacement: passo 3, immagine 1 di 1
    • Carefully peel the panel off of the bottom of the laptop.
  4. ASUS VivoBook S300CA-BBI5T01 Battery Replacement: passo 4, immagine 1 di 1
    • Remove the 7 screws holding the battery in place.
    • Six 3 mm Phillips head screws
    • One 5 mm Phillips head screw
  5. ASUS VivoBook S300CA-BBI5T01 Battery Replacement: passo 5, immagine 1 di 1
    • Disconnect the one flat topped wire connector by carefully using a plastic opening tool to pry up both sides and then lifting the connector from its socket.
  6. ASUS VivoBook S300CA-BBI5T01 Battery Replacement: passo 6, immagine 1 di 1
    • Slide out the battery.
Conclusione
Un commento
Make the Save ESD ?
Konrad Aubreville - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 6
Tutti i Tempi: 3,653
