Salta al contenuto principale
ASUS VivoBook S300C Hard Drive Replacement
Cosa ti serve
  1. ASUS VivoBook S300C Hard Drive Replacement, Remove the bottom cover: passo 1, immagine 1 di 1
    • Remove the 10 screws on the back cover.
    • Some screws are missing from this system. You should take your own notes to make sure you put the correct screws in during reassembly.
  2. ASUS VivoBook S300C Hard Drive Replacement, Remove the hard drive cable: passo 2, immagine 1 di 1
    • Remove the hard drive from the laptop. To do this, the cable is taped to the hard drive caddy. Remove the tape from the cable and disconnect the hard drive from the motherboard.
    • I am also missing screws here. Take your own notes to avoid misplacing screws during reassembly. They should all be the same length.
  3. ASUS VivoBook S300C Hard Drive Replacement, Remove the hard drive from the caddy: passo 3, immagine 1 di 2 ASUS VivoBook S300C Hard Drive Replacement, Remove the hard drive from the caddy: passo 3, immagine 2 di 2
    • Remove the 4 screws holding the hard drive in the caddy. There are two screws on each side.
    • Reassemble the laptop by following the steps in reverse order. This is my first guide, so let me know what I did wrong so I can fix it.
Conclusione
Altre 4 persone hanno completato questa guida.
Cameron
Membro da: 12/02/15
10.353 Reputazione
1 Guida realizzata
Master Techs Membro di Master Techs
Community
322 Membri
2.506 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 14
Tutti i Tempi: 3,487
