Salta al contenuto principale
ASUS VivoBook Flip TP501U Keyboard Panel Replacement
Cosa ti serve
  1. ASUS VivoBook Flip TP501U Keyboard Panel Replacement, Keyboard Panel: passo 1, immagine 1 di 2 ASUS VivoBook Flip TP501U Keyboard Panel Replacement, Keyboard Panel: passo 1, immagine 2 di 2
    • Open the laptop until it is flat and lay it screen down.
    • Remove eight 9.6mm Phillips #00 screws from the bottom of the laptop.
    • Remove two 4.8mm Phillips from the corners of the device.
  2. ASUS VivoBook Flip TP501U Keyboard Panel Replacement: passo 2, immagine 1 di 1
    • Turn the device face up.
    • Use the plastic Opening Pick to separate the keyboard panel from the chassis that was just unscrewed.
    • Pull the panel away from the chassis CAREFULLY, as there are ribbon cables attached between the keyboard and internal electronics.
  3. ASUS VivoBook Flip TP501U Keyboard Panel Replacement: passo 3, immagine 1 di 1
    • With the keyboard panel pulled up, detach the two ribbon cables from the motherboard using the blue tabs on the cables.
    • Remove the keyboard panel completely.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 10
Tutti i Tempi: 1,021
