Introduzione
Need to access the internals of your ASUS VG248? Here's a guide that shows how to remove the frame and open the display.
Strumenti
Parti
Nessuna parte specificata.
Four rubbery covers hide four screws in the rear of the monitor.
Pry out the plastic covers with a stiff pointed tool, like a metal spudger.
Using a thin stiff prying device, like a Jimmy, press in against the bottom clip in the lower left corner (beneath the HDMI logo).
While pressing the clip in, pull up on the lower edge of the bezel. The entire corner should pop free.
Altre 13 persone hanno completato questa guida.
4 Commenti
Hi there, I have a little thunderbug trapped in the LCD is it possible to take the metal casing at the front of to reomve said bug? Thanks
You could yes, but be very careful NOT to introduce dust into the panel!
Hi. A really small bug got stuck within my screen and I accidentally squished it so now it’s dead in there and I want to clean it. How would I remove the top layer of the screen? Because from what I can see it seems like it got squished between the glass and the actual LCD screen itself.
