Introduzione
In this guide, the user will be able to follow step-by-step instructions for replacing the motherboard in his or her ASUS U46E-RAL7 Laptop.
Cosa ti serve
Remove two (2) 9mm x 4mm screws from the back panel with the size 0 Phillips head screwdriver.
Remove two (2) 7mm x 4mm screws from the back panel with the size 0 Phillips head screwdriver.
Remove six (6) 7mm x 4mm screws with the size 0 Phillips head screwdriver.
Remove three (3) 3mm x 3mm screws with the size 0 Phillips head screwdriver.
Remove one (1) 4mm x 4mm screws with the size 0 Phillips head screwdriver.
Flip the device so that the laptop will open away from you to remove the hinge cover behind the screen.
Place index fingers underneath the hinge cover and gently pull up.
The cover will pop off easily with a click.
Remove five (5) 5mm x 4mm screws from the hinge compartments of the device with the size 0 phillips head screwdriver.
Open the screen.
Carefully lift the keyboard panel. The keyboard will be attached to the motherboard by two ribbons.
To disconnect the ribbons, use your fingernails to push down gently on the protruding plastic at the base of the connector. There is a soft click and ribbon releases. Repeat for the other ribbon.
Remove four (4) 7mm x 4mm screws with size 0 phillips head screwdriver.
Remove thirteen (13) 5mm x 4mm screws with size 0 phillips head screwdriver.
