Salta al contenuto principale
ASUS Transformer TF101 Battery Replacement
Cosa ti serve
  1. ASUS Transformer TF101 Battery Replacement, Back Panel: passo 1, immagine 1 di 2 ASUS Transformer TF101 Battery Replacement, Back Panel: passo 1, immagine 2 di 2
    • Use T5 Torx Screwdriver to remove two 4.5 millimeter T5 screws on either side of the port on the bottom of the tablet.
  2. ASUS Transformer TF101 Battery Replacement: passo 2, immagine 1 di 3 ASUS Transformer TF101 Battery Replacement: passo 2, immagine 2 di 3 ASUS Transformer TF101 Battery Replacement: passo 2, immagine 3 di 3
    • Use the Plastic Opening Tool to pry between the main tablet body and the outer rim casing. Remove the outer rim casing by prying all the way around the device and pulling the rim upward.
    • The physical buttons are located on the outside of the rim on the right side, proceed with the guide to locate internal buttons.
  3. ASUS Transformer TF101 Battery Replacement: passo 3, immagine 1 di 1
    • Remove the four 2 millimeter Phillips #00 screws at the corners of the tablet.
  4. ASUS Transformer TF101 Battery Replacement: passo 4, immagine 1 di 1
    • Use a Phillips #00 Screwdriver to remove the three 3 millimeter screws securing the front panel to the back panel found above the camera area, on the top portion of the tablet.
  5. ASUS Transformer TF101 Battery Replacement: passo 5, immagine 1 di 1
    • Use a Phillips #00 Screwdriver to remove the three 3 millimeter screws securing the front panel to the back panel found on the bottom portion of the tablet near the port.
  6. ASUS Transformer TF101 Battery Replacement: passo 6, immagine 1 di 2 ASUS Transformer TF101 Battery Replacement: passo 6, immagine 2 di 2
    • Remove back panel by pulling away from the remaining device.
  7. ASUS Transformer TF101 Battery Replacement, Remove button screws: passo 7, immagine 1 di 2 ASUS Transformer TF101 Battery Replacement, Remove button screws: passo 7, immagine 2 di 2
    • Use a Phillips #00 Screwdriver to remove the three 3 millimeter screws securing the buttons to the back panel.
  8. ASUS Transformer TF101 Battery Replacement, Locate and lift button clip: passo 8, immagine 1 di 3 ASUS Transformer TF101 Battery Replacement, Locate and lift button clip: passo 8, immagine 2 di 3 ASUS Transformer TF101 Battery Replacement, Locate and lift button clip: passo 8, immagine 3 di 3
    • Use Plastic Opening Tool to pry off the clip located towards the bottom of the button component near the metallic strip with a blue end, capped by the black button clip.
    • Remove button component by pulling straight outward from the device.
  9. ASUS Transformer TF101 Battery Replacement, Remove screws: passo 9, immagine 1 di 1
    • Use Phillips #00 Screwdriver to remove four 3 millimeter screws found on the metal panel.
  10. ASUS Transformer TF101 Battery Replacement, Remove metal panel: passo 10, immagine 1 di 1
    • Metal panel is glued to the battery. Remove with care.
    • Use Plastic Opening Tool to pry off the metal panel from the battery starting on the right side corners and working around the rest of the panel.
  11. ASUS Transformer TF101 Battery Replacement, Detach wires: passo 11, immagine 1 di 1
    • Do NOT pry the battery connector upward as shown in this photo. Instead, pull the connector straight out (in the direction of the wires).
  12. ASUS Transformer TF101 Battery Replacement, Remove battery: passo 12, immagine 1 di 3 ASUS Transformer TF101 Battery Replacement, Remove battery: passo 12, immagine 2 di 3 ASUS Transformer TF101 Battery Replacement, Remove battery: passo 12, immagine 3 di 3
    • Battery is glued to device. Remove with care.
    • Peel off tape from around the edges of the battery.
    • Insert Plastic Opening Tool into slot on side of battery found near the wire bundle.
    • Lift up the battery off of the device.
Conclusione
Altre 21 persone hanno completato questa guida.
Sandy Babich
Membro da: 09/23/14
1.909 Reputazione
5 Guide realizzate
Cal Poly, Team 13-9, Forte Fall 2014 Membro di Cal Poly, Team 13-9, Forte Fall 2014
CPSU-FORTE-F14S13G9
5 Membri
12 Guide realizzate
6 Commenti
Ahhhh, the battery connector sides out right?!? Lifting it up would remove its socket from the board as you can see in the last 3 pics.
Also under the middle of the battery is another strip of tape attached to a thin bar the width (long dimension) of the battery which i could see snapping if you attempted to remove the battery without sliding a tool down between the battery and bar.
lukedw - Replica
Where can I purchase the battery? It wasn't on the parts list on this page.
Is it worth the effort replacing the battery for this old tablet when new ones a re more powerful and less expensive?
Any help is appreciated.
Bob
Bob Miksic - Replica
I followed step 11 and pried the battery connector upward. Ended up severing the socket, ruining my entire tablet. Thanks.
Keith Marchell - Replica
Do not pry up battery connector as described in step 11, connector slides off easily. This I now know from following the instructions and will have to purchase a replacement board if I wish to use this tablet again.
Anthony McC - Replica
Replaced the battery with a new one and it’s still not charging. Maybe the problem is with the charger, not the battery.
Yangbin - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 68
Tutti i Tempi: 20,634
